Need help finding some info...
Old Nov 18, 2007 | 11:22 PM
Zaairman's Avatar
Ok, so my F-250 is in need of a new cover for my driver's leather seat. The bottom half has seen much better days, and it has a tear that I doubt can be repaired. So, I figured that I'd try and find a replacement cover for it. Problem is, my truck was born by Ford as an XLT with cloth seats. It has an aftermarket conversion on it by SEVEN O SEVEN Industries (of which 65% I removed ), and the seats have a tag on them that says "Designs West." I cannot find ANY information on either of these companies. Any ideas on what to do?
Old Nov 18, 2007 | 11:48 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Go to a salvage yard, pick out a seat you like, buy it and then bolt it in.
Old Nov 18, 2007 | 11:51 PM
Zaairman's Avatar
The seat itself is fine, I'm wanting to get a new leather cover but don't want for it to be mis-matched...
Old Nov 19, 2007 | 12:03 AM
PSS-Mag's Avatar
It's still likely to be cheaper and 10x's easier than recovering and will look better than just a tie on cover to get an entire seat from a salavage yard.
Then take yours put it in the dorm, throug ha blanket over it and have a couch.
Old Nov 19, 2007 | 08:15 AM
Walkin it Dry's Avatar
Registered User
Take it to an automotive upholstery shop.
I know that sounds really obvious, but the good shops will be able to match whatever you have to a new seatcover. Shop around a little-I know of three different places that could do it.
they'd need the truck for maybe a day, and you can get as little or as much done as you want.
Old Nov 19, 2007 | 08:43 AM
kingfish51's Avatar
Agree, an upholstery shop should be able to replace just the bad panel.
Old Nov 19, 2007 | 09:07 AM
jamzwayne's Avatar
Depending on the issue with the seat.....I like Matt's idea....couches rule
Old Nov 19, 2007 | 08:04 PM
Zaairman's Avatar
Meh... Power seats are expensive and it still wouldn't match... I don't want to have mix n matched seats.
