Power of Observation
Old Oct 22, 2007 | 09:37 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Originally Posted by ian51279
Same here. Too lazy to type that much.
When we moved in here there was only 1 fan in the house.... I installed all the others..... on part of them I had an option of which direction to install the blades/arms....... Didnt realize that if I choose the reverse then those fans would also be reveresed....... So some of them are pitched for clock wise = cool, the other ones are counter clockwise = cool...... So now I have to remember, look and sometimes study which onces are which and which ones need to be going wich direction...... it sucks!!!!!! But I'm to lazy to go change them..... it's easier to study and then flip a switch.... I keep thinking they'll burn up soon and I can replace them.....
CANES676400's Avatar
didnt know people used them. at my house in the keys we only turn the heat on to keep it from freezing up. it smells so bad
Old Oct 22, 2007 | 09:38 PM
quackrstackr's Avatar
Originally Posted by CANES676400
fans spin clock wise most of the time so they can cool. does anybody really switch it to go the other way for heat
I've got one right here above the computer that turns ccw to cool. So does the one in my bedroom...
Old Oct 22, 2007 | 10:02 PM
21 for me
Old Oct 22, 2007 | 11:09 PM
ian51279's Avatar
Originally Posted by bluejay432000
21 for me
Old Oct 22, 2007 | 11:14 PM
Murf's Avatar
I only got 17 right
Old Oct 23, 2007 | 12:09 AM
jiggle's Avatar
My ceiling fan turns counter clockwise.
Old Oct 23, 2007 | 01:06 AM
wild-mtn-rose's Avatar
17 right
Originally Posted by PSS-Mag
I do too.
Helps alot both comfort and heating bill!
Most my fans run 24/7 and when I switch from AC to heat or vice versa, then the fans get switched too.
Ofetn dont even have to use the heat, just turn the fans to push the heat off the cieling down.
Funny we just had this discusion last week at work.
Me too. With a 26' ceiling in the LR, switching the fans to move that heat down from up there is pretty nice, otherwise we're paying to heat space where no one hangs out!!
Old Oct 23, 2007 | 09:21 AM
05supercrew's Avatar
19 score
Old Oct 23, 2007 | 10:16 AM
KSUWildcat's Avatar
Originally Posted by wild-mtn-rose
17 right
I wish I could hang out at the ceiling. Think of the possibilities with all that unused space!
22 for me.
Old Oct 23, 2007 | 01:59 PM
Hitched_Gibson's Avatar
Ah yeah. 22.
Old Oct 23, 2007 | 02:02 PM
Needs some pee-cans in it.
Old Oct 24, 2007 | 12:55 AM
22 for me.
You need sticky little feet like flies have, then you can hang out up there. Be a little hard to get your furniture to stick around though
Old Oct 24, 2007 | 01:30 AM
I got a 24... the one about the FM dial is WRONG. There is a 87.5 Mhz on a standard FM radio tuner...
Cheapskates...
Old Oct 24, 2007 | 07:51 AM
clonetek's Avatar
Cheapskates...
It said lowest WHOLE number.
