Foam tool box cut outs...DIY?
Old Aug 30, 2007 | 01:44 PM
Shane1's Avatar
Anybody make there own foam cut outs for their tool boxes? If so how did you do it? Exacto knife?
Also pics would be cool.
Old Aug 30, 2007 | 03:47 PM
akheloce's Avatar
Yeah, I've done it with my aircraft tools. (you do it to make sure all of your tools got put back)
I laid all the tools out where I wanted them, gave a very light dusting of flat paint (enough to barely see the outline of the tools, but light enough that you can just wipe the tools off- flat works best for this). I would use a color pretty close to the foam, like a dark grey or something. Then, I used a soldering iron with an exacto-type blade (on medium-low heat) to cut it out. It's a long, painstaking process, but the results were pretty good.
Old Aug 30, 2007 | 05:00 PM
scott1981's Avatar
Demel tool. Makes the job alot easier. Use one of the stone bits shaped like a cone
Old Aug 30, 2007 | 06:23 PM
ian51279's Avatar
We have to shadow (that's what we call it) our boxes at work. I trace around the tool with a sharpie and use a razor blade to cut it out.
Old Aug 31, 2007 | 12:53 AM
Photog95's Avatar
I can never seem to be able to find the foam. Where do you get this stuff for a 40" Snap-On box. I hate having to rearange every time I move more than 10 feet.
Old Aug 31, 2007 | 01:43 AM
Shane1's Avatar
Thanks for all the info! that hot exacto knife sounds like a good idea!
I googled "foam tool cutouts" and found some pretty good site. It was pretty pricey IMO. I'm gonna try a hbby shop and see what they have
Old Aug 31, 2007 | 03:43 AM
jbporter's Avatar
Sears sells the foam in packs of three. One sheet is big enough to do one regular sized drawer, when you move to the bigger drawers, they can fit together. Put shelf liner under the foam pads. Arrange all the tools on the foam a couple of times before you cut, I had to redo mine twice because I kept thinking of ways I liked better.
Old Aug 31, 2007 | 10:16 AM
Larry227's Avatar
Foam cutouts sound nice but I would have to buy a second box if I tried it in mine. My collection of pliers alone would take up two or three drawers.
