off topic golf cart help
Old Aug 12, 2007 | 06:01 PM
supercrewser13's Avatar
Ok so i have a very off topic. how do you remove the speed limiter on a golf cart. I am trying to find out asap. always when i use one i want to know how to do it.
Old Aug 12, 2007 | 06:14 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
gas or electric?
Old Aug 12, 2007 | 06:29 PM
gas
Old Aug 12, 2007 | 06:36 PM
PSS-Mag's Avatar
On the ones I've seen it's just a bolt under the gas pedal.
Old Aug 12, 2007 | 06:43 PM
hmmm i dont remeber seeing a bolt i will look is it right under the pedal preventing full throttle? like a coke can under a pedal like the same kind of theory
Old Aug 12, 2007 | 09:44 PM
PSS-Mag's Avatar
Yea it's just threaded through the floor with a rubber bumper on the end for the pedal to hit. Run it al the way down to the floor, so the pedal can go all the way to the floor.
Another method is a governer on the carburator. Which is either a rod restricting how far the throttle can open or a plate bolted either to the carb or intake, for the throttle to hit to keep the butterfly from opening full throttle.
It's going to be something mechanical, very simple and very basic. It's not going to be a special electronic unit or anything like that.
Old Aug 12, 2007 | 10:47 PM
Bowser4x4's Avatar
If it is a club car, there is a "spring" that can be tied back with a cable tie. Try www.buggiesunlimited.com and hit the forums: do a search for your model and year.
Woof
Bowser
Old Aug 13, 2007 | 04:51 PM
Thanks guys for the comments i think i am getting a better idea as to where ihave to be messing around. keep the tricks coming please
Old Aug 13, 2007 | 07:04 PM
Gipraw's Avatar
if ti is gas, you may be able to gfet around it like mentioned above .. if it is electric .. you will have to add an additional solenoid ..
we used to do that all the time to the carts the bag room used .. ticked the golfers off when we would go whizzing by them in a cart that looked just like theirs
Old Aug 13, 2007 | 07:20 PM
gipraw it is gas how did you do it to the cart you are talking about
Old Aug 13, 2007 | 07:44 PM
Gipraw's Avatar
it was electric .. so we just added an additional solenoid ..
