squeaky...
Old Jul 23, 2007 | 07:30 PM
cdnance's Avatar
squeaky...
i have a 97 150, with 177k miles. recently i have noticed a squeaking noise coming from the rear end. anybody have any ideas as to what that might be?
Old Jul 23, 2007 | 07:35 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
can you tell a general driection it's coming from? Like wheel, rear, bed etc...
That will narrow it down to a couple hundred posibilities.
Old Jul 23, 2007 | 07:47 PM
Net Wurker's Avatar
Is it a "squeek-squeek-squeek" that speeds up as you start rolling faster? If so, I would suspect a bad u-joint.
Old Jul 23, 2007 | 07:56 PM
PSS-Mag's Avatar
If it's a high pitched squeak that speeds up with vehicle speed then it could be brake pads or even bearings.
Old Jul 23, 2007 | 08:53 PM
cdnance's Avatar
thanks guys. im going to replace the bearing in the next couple of days. i will let you know if it helped.
Old Jul 23, 2007 | 09:05 PM
bigdad8214's Avatar
jack it up and spin the wheels
Old Jul 23, 2007 | 09:15 PM
PSS-Mag's Avatar
Thats what I would do, that will also tell you which side it is or even if it's the wheels..... like Net Wurker said it could be the ujoints, or could even be in the rear end too.
Then again it may not squeak with out the weight on it so cant totally digard anything if it dont squeak when jacked up.
I'd definalty investigate before just throwing parts at it.
Mine use to have a squeakwith a slight ping only at low speeds, couldn't locate it and couldn't idnetify it. Come to find out my park brake shoe had come apart. (yes I have 4 wheel disc but your park brake is a drum inside the rotor....)
Old Jul 23, 2007 | 09:30 PM
cdnance's Avatar
oh yeah by the way, i forgot to say this. it only does it under load. if that helps any. also i am almost positive that it is not the u-joint. we have checked and checked that thing and cant find any reason it would be doing it.
Old Jul 23, 2007 | 10:26 PM
PSS-Mag's Avatar
So it stops when you let of the gas?
Is this an automatic or standard trans?
Old Jul 23, 2007 | 10:40 PM
cdnance's Avatar
it's an automatic, but 70 percent of the time, it continues squeaking gas or not. well, i mean from acceleration, or backpressure. you know what i mean?
Old Jul 23, 2007 | 11:17 PM
PSS-Mag's Avatar
Yea I think I do....
that sounds like likely out more towards the wheels....
Does it increase or decrease with speed, or stay pretty constant?
Old Jul 23, 2007 | 11:26 PM
cdnance's Avatar
yes. it deffinately changes with speed. i personally think it is the bearings, but i want to get your opinion.
Old Jul 23, 2007 | 11:34 PM
PSS-Mag's Avatar
It could be a brake pad, they have rivets that are designed to squeak when they get so thin to let you know it's time to change it. Or could be the brake pad on the emergency brake. Could be bearings, could be a rock in your brake. It could aslo be a rock between your brake caliber and your wheel. I have a wheel that I now use as a trailer stand that practically got cut in half that way. Tire shop said they'd never seen anything like it. I had never heard of it but apparently it can happen.
Best thing to do is tear into it and see if you find anything along the way. Then go get the parts you find need replaced. 177K miles it could be any of those and may find it needs all of them.
Old Jul 23, 2007 | 11:36 PM
cdnance's Avatar
i have drums in the rear. the only thing i could think of other than a bearing is maybe a shoe.
Old Jul 23, 2007 | 11:51 PM
PSS-Mag's Avatar
Yea could be a shoe or a rock inside the drum. That would be nice. Means you still get to beat the drum off, but that beats pulling the axel and you'll have to pull beat the drum off to get the axel out anyway.
