computer help
Old Jul 21, 2007 | 04:38 PM
bigdad8214's Avatar
computer help
I don't know what happend but now when I open a link or another window its not in the center of my screen, its half way down or over on one side. How do I get it to center itself like it did before?
Windows XP
Old Jul 21, 2007 | 04:46 PM
F150Europe's Avatar
Position the window in the upper left corner.
Then while holding your leftmousebutton, drag the lower right corner to a full screen.
Old Jul 21, 2007 | 04:57 PM
bigdad8214's Avatar
When I open the link or say your photo gallery it is full size, I just have to drag it up. I didn't have to do that before
Old Jul 21, 2007 | 05:09 PM
kobiashi's Avatar
Did you have an external monitor hooked up to your machine (if laptop)
or a second (or different) monitor hooked up (if desktop)
Old Jul 22, 2007 | 01:05 AM
Larry227's Avatar
If you mean mean when the new window opens it's not full screen then move it to where you want it to open the next time then close it and try again. That seems to work for me.
If it's opening in full screen and part of it is totally off the screen then that's something else. Which is it?
Old Jul 22, 2007 | 01:06 AM
Larry227's Avatar
Sorry, I misread that the first time.
Are you sure it's in full screen when it opens or just seems to be?
Old Jul 22, 2007 | 10:33 AM
bigdad8214's Avatar
Yah its full screen, any gallery or link opens half way down. It just started doing this yesterday.
Old Jul 22, 2007 | 10:42 AM
Larry227's Avatar
What happens if you double click the title bar?
Old Jul 22, 2007 | 11:57 AM
bigdad8214's Avatar
Well that fixed it, but then when I close it and try again its the same. How did you save that pic of your desk top?
Old Jul 22, 2007 | 12:45 PM
Impact9's Avatar
Windows always open up to the last configuration that they was closed on. So set your one window where you want it close out all the programs associated then reopen. It should be reset then.
Old Jul 22, 2007 | 12:52 PM
Larry227's Avatar
If double clicking the title bar makes it expand then it's not opening in full screen like you think it is.
Do what Impact9 said.
As far as the screenshot, I use Hypersnap but it can also be done by just hitting the "Print Screen" key and then opening Paint or any other photo program and pasting from clipboard then save it.
Old Jul 22, 2007 | 01:25 PM
bigdad8214's Avatar
That didn't work.
Old Jul 22, 2007 | 04:15 PM
Impact9's Avatar
hmm I know I've had this problem before but for the life of me I can't recall what I did to fix it. I'm sure you've rebooted since this started. yes?
Old Jul 22, 2007 | 06:40 PM
bigdad8214's Avatar
That was the first thing I did.... I know its something easy.
Old Jul 22, 2007 | 07:26 PM
shroomie's Avatar
There is a certain key you can hold when closing a window that will tell Windows to open a program window in that position every time. I can't seem to recall what it is, but put the window where you want it then hold Ctrl or Shift while doing a File>Close. If those don't work, maybe try Alt or the Windows Key.
