alive... again
Old Jun 29, 2007 | 07:19 PM
Camarothatcould's Avatar
alive... again
Click here to watch Loud-N-Proud
inner valve springs now installed. High RPM's here I come
Old Jun 29, 2007 | 07:21 PM
bigdad8214's Avatar
That sounds like fun
Old Jun 29, 2007 | 07:24 PM
khendrix2374's Avatar
What size Ford motor you put in that thing? LOL
Old Jun 29, 2007 | 07:35 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Sounds 100 times better than it did the first video.
Now if you can just get it to stop spinning the tires and plant the power to hte ground, then it might beable to move the old rust bucket at a good little pace. Might keep up or even pass the stock Mustangs.
Just razzing ya dude.
Does sound good, now you've got the torque, so what are your plans to get it to hook up?
Maybe a higher (numericly lower) rear end?
Old Jun 29, 2007 | 07:39 PM
Mickey Thompson ET Drags or Street Radials
3.73's are staying
Old Jun 29, 2007 | 08:22 PM
PSS-Mag's Avatar
3.73's are staying
From the looks of that burn out, looks like you have way over powered the little boys 3.73's by 1 or 2 ponies. Unless second gear is a huge ratio change.
Looks like you might could have... reluntantly I say but maybe, you might have stepped up close to the 3.05. I dont know though, those are for the big boys making serious power.
I'd atleast take a set of 3.55's to the track with me and make a pass with each. I'd say you'll see faster times with the 3.55's, just because you'll beable to get all the way in to the pedal faster. Putting all the power to use for more of the track.
With that burn out, I'd guess one of three things will happen...1. You will either spin all the way through the 1/4 mile. Hopefully wont loose control and put it in the wall. Tires will be doing 110 mph, but the car will only be doing 80mph. 2. You will hit your top speed with a 1/4 mmile of track left to go. 3. You will never get a chance to open it all the way up because every time you try then it will try to break loose.
Old Jun 30, 2007 | 12:15 AM
Wookie's Avatar
Seeing that it was a piece-o-Chevy you should have titled this thread: alive... again, but not for long.
Old Jun 30, 2007 | 01:12 AM
holy ****, i think i forgot to laugh
