Computer won't boot, what to do?
Old Jun 28, 2007 | 02:17 PM
  #31
F150Europe's Avatar
Update
There is nothing wrong with the hd.
Computer is working now for two days.No problems.
I have checked connectors once again.
It is probably a bad connector or a loose wire in a connector.
Anyway, I am glad it's not the hd.
Old Jun 28, 2007 | 02:32 PM
  #32
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Originally Posted by bmalone
I have in the past set a drive on top of a block of ice (outside the case) and that kept it cool enough for quite a while. I would think dry ice would do the same, but haven't tried it.
Thats a good idea and could give a couple hours of use of a bad HD.
Old Jun 28, 2007 | 04:24 PM
  #33
sysman_rick's Avatar
Post
More than likely a mobo or a power supply. Open the case & check for a led on power supply or on the mobo. If u r not getting any beeps or fan noises
it's the psu. If you feel handy,reseat all connectors & boards in the case.
As a last result u could reset the BIOS(check the user's manual) but that's a LAST DITCH move.
