Somebody PLEASE explain this to me....
Old Jun 15, 2007 | 03:07 PM
89Lariat's Avatar
Originally Posted by Copperhead64
***update****
''It appears he was trying to repair a malfunctioning starter and left it in drive,'' said Detective Robert Williams, a Miami-Dade police spokesman. ``It seemed to trigger the ignition, and ran him over.''
How do you replace a starter for a 1993 Buick LeSabre?
Answer :
"It'll be center, front, right under the engine. Disconnect the battery, then remove the wires from the starter. They'll be connected at two points. Just look at the new starter to figure out where to find them on the old one. There should be two bolts, one on the front and one in back holding it in. One of these also hold a small plastic sheild in place. You might have to wiggle the starter around a bit to get it out".(Google search)
natural selection
Old Jun 15, 2007 | 03:18 PM
Nedward's Avatar
How do we submit this for a "Darwin Award"?
Old Jun 15, 2007 | 03:52 PM
Net Wurker's Avatar
I'm tellin' you guys, Doris Jones just got away with murder.
Old Jun 15, 2007 | 05:51 PM
xflyboy's Avatar
Originally Posted by wild-mtn-rose
You can crank a vehicle engine using a screwdriver to short the 2 terminals on your starter solenoid together. I'm not sure if that's what happened or not because he wouldn't have to be under the car to do this. Most starter solenoids are located on the firewall inside the engine compartment. Although most automatics will not crank if the transmission is in gear??? Weird.
sorry rose, not on gm's like that. the solenoid is right on the starter
