computer help please!!!
Old Apr 27, 2007 | 10:03 PM
ridge's Avatar
ok well im having problems with my computer, everytime i listen to music, or listen to anything really i get this choppy sound, it happens everytime, it does it once every so many seconds why is that? it never did it before and i want to fix it so please help me
Old Apr 27, 2007 | 10:23 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
First when was the last time that you rebooted?
Second, does it do it with any audio program or just one?
If your using windows media player try a diferent program. If that works tehn it's a software issue.
Third if all else is fine, then update your audio drivers.
Final call tech support.
Old Apr 27, 2007 | 10:29 PM
ridge's Avatar
my computer was just rebooted last week, it does it on you tube and all.
Old Apr 27, 2007 | 11:33 PM
Larry227's Avatar
Are you sure it's not your speakers? Have you moved them recently?
If you're watching video does it get choppy too or just your sound? Try rebooting and see if that helps. I guess it's possible you could have too many processes running in the background and dragging you down too. XP or Vista?
If none of the above helps you could try updating the sound drivers like PSS-Mag said.
Old Apr 28, 2007 | 02:50 AM
ridge's Avatar
i tried to update the drivers but it said theres no new updates out there, i have xp, and only have aol, photoshop, and wintv on my computer
Old Apr 28, 2007 | 10:23 AM
Larry227's Avatar
You would have to try updating them manually by finding out exactly what sound chipset you have and checking the manufacturers site, then downloading them and updating using the Advanced method and browsing to them if they don't come in an .exe
If that's what you've already done either forget what I said or try re-installing whatever newest ones are available. You could also check Windows Updates, scan using the "Custom" button and then check under Hardware on the left.
Just for kicks, tell us how many processes you have running. Right click the task bar and choose Task Manager, then click the Processes tab and look in the lower left corner to see how many are running.
Old Apr 28, 2007 | 10:57 AM
PSS-Mag's Avatar
What brand and model is this computer?
Old Apr 28, 2007 | 08:17 PM
ridge's Avatar
Gateway 702GE
Old Apr 28, 2007 | 08:35 PM
kobiashi's Avatar
This is where I fulfill the equal time requirements of the forum -
Lose the Gateway - get one of these.
Old Apr 29, 2007 | 01:34 AM
PSS-Mag's Avatar
Originally Posted by ridge
Gateway 702GE
Download and install this....
http://support.gateway.com/support/d...%205.10.0.5136
Even if you have driver version 5.10.0.5136 already installed, sometimes drivers become curropt. Installing a fresh one over the new one will never hurt anything.
Old Apr 29, 2007 | 01:57 AM
ridge's Avatar
i did that and its still makes the studder, or skip whateever, i think it was a problem with the reboot but im not all that sure
Old Apr 29, 2007 | 02:00 AM
PSS-Mag's Avatar
You should reboot after installing the drivers.
If it happens every time you boot the system then it's a critical problem thats not just going to go away.
