Ford recalls 527,000 Escape SUVs
Ford certainly didn’t need this. I’m always curious about recalls like this one where it’s a small thing like a wire harness or a contaminated ball joint or this latest cruise control issue. I know Ford makes a lot of cars and trucks and recalls are not special to just Ford but you would think that with the decades of experience building vehicles that drive in all types of climate, terrain and weather issues like placing a wiring harness on an area of the vehicle that the engineers know will be exposed to the elements without taking the steps to properly protect it would not be a problem. Recalls are going to happen from time to time but it seems to me that a lot of recalls are stupid things like this one.
Originally Posted by Quintin
If engineers knew what they were doing, me and thousands of other technicians from all brands wouldn't have a job.
I imagine its possible that the engineers got it right and some 3rd party supplier just didn't follow specs and/or cut corners and produced a batch of bad parts.
Dont know if that is the case but I'm sure it could be.
Just remember, engineers dont hold the purse strings. Good engineers will validate a product through alpha and beta testing, this would reveal any potential defects. However, this requires R&D which is pricey. Ford's attempt to increase profits and cut spending has eliminated a good portion of needed R&D. An engineer only has as much time and resources as allotted by management. If the pressure is on to release a product as soon as possible and as cheap as possible, then obviously something has to suffer, quality in this case.
Originally Posted by ddellwo
Have you seen the engine compartment of the new diesel-equipped Super Duty? I am convinced this was designed for no other reason but to make the lives of Ford mechanics a living he11......
You guys need to gather all of your info before you start bagging on the engineers and designers.
Taken straight from the AP news release:
The company said the recall would address missing or incorrectly installed seals on the wiring harness of the antilock brake connector.
Water and contaminants such as brake fluid or road salt could enter the connector and cause corrosion.
Trust me... you wouldn't believe some of the crap that I see happen during manufacture.
There are plenty of other things to bash them on each according to his or her own tastes of course.
Like the poorly designed center console in my 07 FX4 that I’m using as a garbage can right now. But I digress. I’m sure most recalls are something along these lines where the issue occurred during assembly and has nothing to do with the engineers or designers. I imagine that recalls because of design or engineering flaws are much more cost prohibitive and therefore don’t happen unless there are major safety issues unlike a simple problem like this one.So is it just perception that domestic trucks have more recalls than non domestic or are less that reliable? I admit that when I went from my 04 Tacoma to my 07 FX4 my first and only concern was reliability. I love my FX4 and I desperately want it to last a long time.
