Gun Nut test.
Originally Posted by Wookie
Ok, I pulled off an
NRA Member
You are 86% of a gun nut!
You have excellent skills in weapons handling. I could definetly trust you to cover my back. Matter of fact, you're probably packing right now!
There are a couple of questions that I was not sure about and had to guess at. Does anybody know the correct answers? I put an X next to the answer that I guessed.
How does the reloading mechanism in the M-16 function?I thought this question was kinda goofy myself. Yes, the M16 has a gas tube, and yes, it uses gas blow back to cycle the action. It doesn't have a "piston rod," designs like the M14 and AK47 use gas pistons. The proper terminology is "direct gas impingement."
Gas blow-back
Gas piston rod
Gas tube X
How many different individual parts are contained in a stock Glock?34 is correct.
8
20
34 X
How many states allow citizens to carry concealed handguns without needing a license?I'm not sure here either, I think I chose 2.
7
38
2 X
Which of these handguns may be carried through a metal detector without triggering the alarm?
Springfield XD
Glock 21
Kel-Tech P32 X
None of the above
NRA Member
Gas blow-back
Gas piston rod
Gas tube X
8
20
34 X
7
38
2 X
Springfield XD
Glock 21
Kel-Tech P32 X
None of the above
The math does not seem to work out here, I went back and retook it and still got an 86%. I think that I may have put the right answer on the test and the wrong answer here in my original post. Or the test has a maximum correct percentage.
I scored a 62% percent, but I was just guessing. I don't know much about guns. I think I actually knew maybe one question. I'm pretty sure the M1 Garand holds 8 in a clip, but that's from playing Call of Duty.
I only "think" I knew 1 or 2 answers. I didn't see where it said what I got right or wrong, but still scored:
Plinker
You are 44% of a gun nut!
You're probably either a seasonal hunter or someone with a decent head knowledge of guns. Keep working at it, and you could really be a force to be reckoned with!
I haven't hunted in about ten years... and then it was only 20GA and .22
Plinker
I feel like such a Nancy!!!
Plinker
You are 41% of a gun nut!
Plinker
Originally Posted by RED WING NUT
48% Plinker
I didn't read any questions. Just went through and filled in random answers.
Originally Posted by PSS-Mag
The military weapons questions were bogus, 1/2 those guns I've never owned, or If I have was just for trading material.....
Originally Posted by PONY_DRIVER
WhoopTeeF'ingdo.
Thats what my grandpa use to say all the time....
His body actions were hilarious when hed do it too, a littel kick/jump and one hand in the air.
That doesn't make the test 'bogus', although I do not think it was very well written/worded. But that's another story. Think of that 'quiz' as a CLEP text for guns.
There are literally 1000's of various actions out there even in the last 50 years, many are variants off of 100's of patents 100 years old, but each works differently in some manner and many still are completely unique. I probably wouldn't pass an indepth test on those, because there are just to many....
My buddy, gun freak, took the test...92%
Check out what he's selling on http://www.gunbroker.com/Auction/Vie...?Item=63566042
Edit: to correct url
