I hate when my gf is right about my truck
Old Dec 30, 2006 | 09:55 PM
jezushadlonghar's Avatar
Here's a quick story that may teach others to listen to their significant others with truck advice. About 3 months ago I replaced my pads and rotors (with the help of my gf's father). Recently, I developed a grinding noise on hard braking, it sounded like my pads were completely worn. I pulled 3 wheels and everything looked perfect. I told my gf what I had done and of course she rationally replied, "why didn't you pull the last wheel?" Of course I should have but I assumed it would have revealed the same and I got lazy. Well, recently I came to my senses and decided to pull the remaining wheel. The backing plate had loosened from the outside pad and was grinding on the rotor. After a quick pad change all is well, it even stopped a clunking sound I had when I would accelerate from a stop. I guess that's what I get for getting involved with a mechanic's daughter.
Old Dec 30, 2006 | 10:00 PM
Can she cook?
As long as you arent playing with his "tool(s)"
But seriously tho, never hurts to do a check up on your own work after a while a month or so.
-Patrick
Old Dec 30, 2006 | 10:01 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Not sure that mechanics daughter had anything to do with it.
You had 4 possibilities for a root cause, you checked 3 of them, I'd say it was process of elimination. She played the odds, that if one of 4 was bad, 3 were good, then odds are it is the last one.
Old Dec 30, 2006 | 10:20 PM
NASSTY's Avatar
You should have let her test drive the truck.She may have been able to tell what side the grinding noise was coming from?Then you would've only had to remove 2 wheels.
Old Jan 5, 2007 | 12:48 PM
Point taken, I should have been able to localize it, but that's part of the learning curve.
Old Jan 5, 2007 | 12:58 PM
jamzwayne's Avatar
Originally Posted by Stealth
Can she cook?
Yeah, if she can cook.....hang on to this one.
