How important is keeping a PC cool?
Old Dec 20, 2006 | 05:03 PM
98Lariet4x4's Avatar
Originally Posted by Grim
While I'm not trying to analyze whether or not additional fans are necessarily better, this statement simply isn't true. Faster air at a fixed temperature will always remove more heat than slower air. It is one of the basic principles of heat transfer.
If you have a standard desk-style computer case, you'll want to set up the front fan to blow in and the rear fans to blow out. ATX computer cases were designed specifically with this air flow path in mind.
Grim
You're right. I meant volume of air. If there's too much air moving through, not all of it absorbs heat...
Old Dec 20, 2006 | 05:36 PM
Grim's Avatar
That's true, the efficiency can go down as the volumetric flow goes up.
BTW, I notice you're an LSU fan. I really need LSU to blow out Notre Dame in the Sugar Bowl, because I've been running a lot of smack here about how the SEC rocks and ND is overrated!
Grim
