engine swap
engine swap
im new to this forum thought i would join up to see if i could get some help it would be greatly appreciated. i have a 97 f150 i blew the engine and wanted to get more power so this mechanic in bradenton told me i could put a 2002 harley davidson motor and trainee in it i did and after 8000 its still not running what i have done so far is motor engine harness i think i need a diablo sport to dis engage the ignition kill and an air charge cooler motor did not come with one and a 2002 harley instrument cluster am i on the right track or do i need more or less? need help thanks jason
nori, you might want to post this in the engine section. The General Discuss will not result in much help.
Hello Jason.
In the supercharger and turbo section there is lots of good advice and how others have done it.
Good luck
Engines
Superchargers & Turbochargers
Chips, Tuners & Programming
Hope these help out, but don't be a stranger to the DG.
Originally Posted by adrianspeeder
Periods help too. I'm not being a smart *** either, as your post is really hard to follow.
Adrianspeeder
Adrianspeeder
Enjoy!!!
hey thanks guys. ill use periods from here on out. if any of you know of any specific posts please let me know. i know its gonna take me a while to go through all these. jason
Adrianspeeder
Not sure that I can help, but I think I see.....
You are installing a HD engine in a non HD truck, once you got it in, now it won't start.
Correct?
What was the orginal engine? (4.6 or 5.4)
Other handy info for correct answers...
Where did the engine come from?
Did you get a new PCM and harness?
Like Adrian said, there are litterally 1000 + things to check, what have you done, what have you checked and what is it doing?
Will the starter turn?
Does it have fire?
Does it hit at all?
Does it back fire? If so, then is it out the Throttle body or the exhaust?
Correct?
Does it have fire?
Does it hit at all?
alright guys, sorry i havent posted here last couple days mike has been doing a good job helping me out. hes waiting on a response from a guy he talked to a while back. any who heres what i got. 97 f150 xlt harley motor, tranny, and ecu. also changed out engine bay harness. mike has told me i need fuel system upgrade, left side harness, dash harness, instrument cluster, intercooler pump mounting bracket, and possibly the tranny harness, but i think i already did that. i guess mike is trying to find out if i can use a dash harness and instrument cluster from any 99 or up model as long as it has at least the xlt options. ford has told me the harley cluster is different from any other, im not sure i might still be able to use it. any help is greatly appreciated. jason
