Attention Network Admins!!!
Help me please!!!
We had a power outage last weekend and come to find out, my PDC Emulator/ALL FSMO Role Holder (Win2K Domain) doesn't like being on backup power.
So, in a pinch, I seized all of the FSMO roles to another DC, and got the domain back up and running when the power came back up. Now, the server is running like a top, but I can't plug it back in to the domain, because IT still thinks it holds all of the FSMO roles and I can't afford problems on the domain today (We have a new client in house today and tomorrow).
I need to remove all of the FSMO roles off of this server WITHOUT connecting it to the domain. I also need to remove AD from it and make it know that it is just a MEMBER and not a DC or GC...
TIA,
Dan (BRUZRs_Daddy)
TIA,
Dan (BRUZRs_Daddy)
Try these links...
http://www.petri.co.il/transferring_fsmo_roles.htm
http://www.chicagotech.net/ad.htm
Why demote it?
and why without a network connection?
Why demote it?
Originally Posted by vader716
Why demote it?
STUPID DELLS...
Originally Posted by dzervit
Here's a wacky thought... if your stable right now then wait a few days until the new client is gone, then jack things up. Why F with it now?
You only have one DC?
Why not transfer the roles back to the stable unit and leave the unstable one as your backup...better than only have one DC.
I would never have just one DC that is very risky.
Plug it in and see what happens! Then let us know how it goes.
What's the worst that could happen? Won't they just fight over the roles, until you remove it from the DC that now has all of them? Or just remove the roles from the troubled DC and then put it back on the network.
So why not just demote it than?
I'm confused where the issue is?
Originally Posted by BRUZRs_Daddy
It won't successfully run dcpromo. Or do I tell it that "This is the last domain controller in the domain"?
You could do that providing it isn't on the network...
The "best practice" thing to do at this point would be to blow away the original server and rebuild it.
There are warnings about bringing a DC back online that held FSMO roles, once those roles have been seized.
From Here: http://support.microsoft.com/kb/255504/
A domain controller whose FSMO roles have been seized should not be permitted to communicate with existing domain controllers in the forest. In this scenario, you should either format the hard disk and reinstall the operating system on such domain controllers or forcibly demote such domain controllers on a private network and then remove their metadata on a surviving domain controller in the forest by using the ntdsutil /metadata cleanup command. The risk of introducing a former FSMO role holder whose role has been seized into the forest is that the original role holder may continue to operate as before until it inbound-replicates knowledge of the role seizure. Known risks of two domain controllers owning the same FSMO roles include creating security principals that have overlapping RID pools, and other problems.
