Hello all
Old Aug 20, 2006 | 12:49 AM
scott5626's Avatar
Hello all
Hi I'm new here I stumbled onto this website. I am sure I will learn alot about my truck esp how to turn that blasted chime seatbelt warning off for the passenger.
Old Aug 20, 2006 | 01:21 AM
lovetrucks's Avatar
Hey Scott. Welcome......nice truck and awsome rims.
Old Aug 20, 2006 | 01:37 AM
Oxlander's Avatar
Welcome aboard.
That chime is called a "belt minder" look in your manual for the steps to deactivating it. You can also seach the forum using the search feature. I've seen many write-ups about it.
once again welcome and enjoy.
ox
Old Aug 20, 2006 | 02:06 AM
wild-mtn-rose's Avatar
Old Aug 20, 2006 | 10:10 AM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Well looky here, right off the bat and you get help....
Welcome to the best Ford truck site on the net.
Though owning an F150 is not a prerequisite, you'll find most of us do.
Ford Owners Manual
Deactivating/Activating the Belt Minder feature:
The Belt Minder feature can be deactivated/activated by performing the following procedure:
Before following the procedure, make sure that:
The parking brake is set
The gearshift is in the P (Park) (automatic transmission) or the neutral position (manual transmission).
The ignition switch is in the off position
All vehicle doors are closed
The driver’s safety belt is unbuckled
The parklamps/headlamps are in the OFF position (if vehicle is equipped with auto lamps, this will not affect the procedure.)
To reduce the risk of injury, do not deactivate/activate the Belt Minder feature while driving the vehicle.
Turn the ignition switch to the RUN (or ON) position. (DO NOT START THE ENGINE)
Wait until the safety belt warning lamp turns off. (Approximately 1-2 minutes)
Steps 3-5 must be completed with in 60 seconds or the procedure will have to be repeated.
Buckle and unbuckle the safety belt three times, ending with the safety belt unbuckled. This can be done before or during the Belt Minder warning activation.
Turn on the parklamps/headlamps, turn off the parklamps headlamps.
Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled.
After Step 5 the safety belt warning light will be turned on for three seconds.
With in seven seconds of the safety belt warning light turning off, buckle then unbuckle the safety belt.
This will enable Belt Minder if it is currently disabled, or disable Belt Minder if it is currently enabled.
Old Aug 20, 2006 | 11:48 AM
scott5626's Avatar
TY very much, I have disabled the driver side chime is there any way to disable the passenger? I have tried these same steps with the passenger but it didnt seem t work.
Old Aug 20, 2006 | 11:58 AM
PSS-Mag's Avatar
Hmm, that should have disabled it.
Mine don't have a drivers and passenger chime. It really wouldn't make since to have one on the passenger because there is not always a passenger, are you sure it's not another minder of some kind?
Old Aug 20, 2006 | 12:00 PM
vader716's Avatar
welcome...
here is my standard reply to the seat belt chime..
Originally Posted by An Old Vader Quote
The disable for the seat belt warning was too complicated so I just buckle it and sit in front of it.
Old Aug 20, 2006 | 02:35 PM
scott5626's Avatar
Yes the passenger warning chime only goes off when I have someone riding with me unbuckled.
Old Aug 20, 2006 | 04:30 PM
Rockpick's Avatar
Moderator &
Hi Scott. Welcome to f150online.com.
As a courtesy to the dialup users at the site, we'd really appreciate it if you'd downsize the pics. A simple and free way to do this is to utilize a f150online.com gallery to post your pictures to our forums.
Check it out -- it's free and VERY simple to utilize.
Again, welcome aboard!
Old Aug 20, 2006 | 05:48 PM
PSS-Mag's Avatar
I'd be inclined to try the same procedure using the passenger seatbelt.
Old Aug 20, 2006 | 06:14 PM
scott5626's Avatar
Better
Old Aug 20, 2006 | 06:59 PM
PSS-Mag's Avatar
That took care of it?
Old Aug 20, 2006 | 08:45 PM
scott5626's Avatar
Better (Pic Smaller) ...no I did try the same code procedure to no avail. Im about ready to go to the junkyard to get a buckle.
