Whats Up Guys And Gals?
Originally Posted by lees99f150
Zap, how easy is it to weld cast. the guys at work have a hard time with it. it always seems to crack after its cooled down.
thats a toughie...are the parts cracked or are this new stuff?
anyway..
cast is in diffrent grades and without getting into it its best to (if its a crack) grind out the crack a little bit to get it to good metal..no rust and yuk..
pre heat with a torch..but not so hot...kinda like its ready for eggs..
tig weld with nickle 99 or if you use a stick welder get the same alloy rod...
weld fast...
after done reheat with a torch again to kinda "anneal" it..
the best thing after that is to bury them in a REAL BIG box of vermiculite...it will let them cool off overnite rather in hrs...
the cooling is the problem...
...zap!
the cast is cracked and soaked with oil. they do pre-heat it and try to slowly cool it but we are fixing 5000lb axle housings out of Caterpillar Haul Trucks. after a few attempts it is fixed but it doesn't always look pretty.
...zap!
