Computer Folks got a quick question
Old Jul 21, 2006 | 01:22 PM
jdoggfx4's Avatar
I have a friends laptop and when you try to boot it up it gets to the windows login screen then has a error of (Isass.exe-System Error) Any Ideas!!!!
Old Jul 21, 2006 | 01:23 PM
UrbanCowboy's Avatar
Good luck with that. Isass.exe might be corrupt. Can it boot to a prompt or in safe mode? You can borrow a copy of lssas.exe from another computer. It's an L btw not an I.
Old Jul 21, 2006 | 01:34 PM
jdoggfx4's Avatar
I can not boot into safe mode. Once I borrow a copy of it how do I get it on there with not being able to get past the login screen?
Old Jul 21, 2006 | 01:35 PM
You can't. That's why I asked.
Old Jul 21, 2006 | 01:37 PM
jdoggfx4's Avatar
Thanks. Any idea what may cause this kinda problem?
Old Jul 21, 2006 | 01:38 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
If it is a capitol L you are ok......
If it is lower case L then that is a virus.... This is from the same family as W32.Sasser....... which has many relations
If it's the virus, good luck... I can point you to the directions for a complete recovery but it's not an easy road.
Old Jul 21, 2006 | 01:42 PM
jdoggfx4's Avatar
I would have to assume that it is the lower case L since I thought it was a Capital I so any help would be great I was thinking of pulling the hard drive, setting it as a slave and just getting the important stuff off it and then reformat, But I'm open to ideas.
Old Jul 21, 2006 | 01:43 PM
From the sound of it; I'm sure he's talking about Lsass.exe
Why dont you clue us in on how to fix it
Old Jul 21, 2006 | 01:57 PM
kobiashi's Avatar
Old Jul 21, 2006 | 02:00 PM
PSS-Mag's Avatar
From another poster with same virus on another forum....
Originally Posted by Russ Wanchisen
Good News everybody!
After suffering from a (seemingly catastrophic) fatal: "lsass.exe - System Error, Object Name not found" boot msg, I was able to successfully recover the OS and get my PC back up & running again! (even without an XP install CD)!
Here's how I did it:
On a separate machine, I navigated over to Microsoft's website and looked into the details of creating a set of Windows XP Setup boot disks. I found all the necessary information here: ( http://support.microsoft.com/default...b;en-us;310994 ). Since my home PC (the one with the lsass.exe error) was running XP Home Edition with SP1, the "winxpsp1_en_hom_bf.exe" file was appropriate for me. That program generated six (6) floppy disks which I subsequently used to boot up my XP Home machine and get into the "Microsoft Windows Recovery Console" mode as described here: http://support.microsoft.com/default...b;en-us;307654 "Recovery Console" mode is a DOS-like mode with limited access to the Windows directory system files (it supports FAT & NTFS file formats, but file access is limited to only the "root" OS sub-folders. User data files are not accessible in "Recovery Console" mode).
OK, now that I was able to boot from the floppies (and access the OS system files), I pretty much followed all the details presented by Charlie White as described in his article "Windows XP crashed? Here's help" (quick-link here: http://www.tunexp.com/faqs/windows_x...ed_heres_help/ ).
In summary, the instructions he provides allow you to effectively perform a manual system restore on your machine.
So, now in the future, if your machine fails on boot-up, don't fret! First try to force a "manual system restore"... If all goes well, you should have your machine back up/running in no time!
Good luck!
Russ
N.B. All the details in Charlie White's article are correct except a small detail in Part 1 where you grab the original system repair files out of the "c:\windows\repair" subdirectory: Specifically, on my machine, the "c:\windows\repair\system" file was actually called "c:\windows\repair\system.bak" (note the ".bak" suffix). As such, the line where he says to
"copy C:\windows\repair\system C:\windows\system32\config\system",
should actually read:
"copy C:\windows\repair\system.bak C:\windows\system32\config\system"
Old Jul 21, 2006 | 02:03 PM
PSS-Mag's Avatar
Then you;ll aslo need
Originally Posted by EiD_Sir_Airman01
It appears you have the SASSER WORM, lsass.exe has a flaw in it, sasser worm attacks that flaw and causes problems for the system, grab the latest Stinger from Network Associates(Creators of McAfee Virus Scan), grab this patch http://www.microsoft.com/downloads/d...displaylang=en after grabbing those 2, turn off system restore, unplug ur computer from the internet line, run Stinger, it should remove the crap that is causing that, afterwards, install the patch, then enable the windows firewall and restart computer than renable the System Restore
Old Jul 21, 2006 | 02:14 PM
jdoggfx4's Avatar
Thanks for the info I think I might just turn the harddrive into a slave and pull what info they need and reformat it.
Old Jul 21, 2006 | 02:18 PM
PSS-Mag's Avatar
Yea thats what I would do too if there wasnt anything really important on it.
Be sure the master is up to date before hooking the infected drive up.
Old Jul 21, 2006 | 02:22 PM
jdoggfx4's Avatar
I did I pulled all the important info and then scanned the folders and files I pulled. They all came up clean.
Old Jul 21, 2006 | 03:33 PM
FordWask's Avatar
Originally Posted by kobiashi
hahaha.
