oil filter exploded upon engine startup
Old May 24, 2006 | 09:22 PM
brisam111's Avatar
Exclamation oil filter exploded upon engine startup
when i started my truck 6 mcyl 4x4 the oil filter split open likek a can ...any suggestions
Old May 24, 2006 | 09:26 PM
Quintin's Avatar
Sure. Hold the keyboard a little closer to the engine so I can see what's wrong.
We need more info. We know it's a six cylinder. Which one? And which year? 300 or 4.2? Usually when the oil filter blows up, the pressure relief valve in the oil pump is stuck. Or maybe you just got a defective filter.
Old May 24, 2006 | 09:34 PM
nvrenuff's Avatar
too funny
Old May 25, 2006 | 12:40 AM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
BEST REPLY OF THE WEEK AWARD!!!!!!
Old May 25, 2006 | 12:49 AM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
That's got to be the best reply that I have ever heard... er seen... err read or whatever!
Old May 25, 2006 | 12:50 AM
expy03's Avatar
I'll second that nomination!!
Old May 25, 2006 | 09:25 AM
TruBluSuperCrew's Avatar
You may have better luck in the engine section of this forum if you don't have any better luck here. I have no idea what would have caused it. These guys like to joke around too, so don't take it to heart.
Old May 27, 2006 | 06:51 PM
Reloader's Avatar
[QUOTE=Quintin]Sure. Hold the keyboard a little closer to the engine so I can see what's wrong.
That has to be one of the better ones I have seen. Goes right along with the blonde secretary putting her monitor on the photocopy machine screen side down so she can make copies of her Word document!
Nanners for Quintin!
Old May 27, 2006 | 07:02 PM
silversvt04's Avatar
[QUOTE=Reloader]
that works better with a lap top.
Old May 27, 2006 | 07:11 PM
mountaineer02v8's Avatar
Old May 29, 2006 | 03:20 PM
northernnorm's Avatar
Did you actually see the split?? If so POST PICS!! If not, check that when you last changed it, you never left the old oil seal ring stuck on the mount. I've had that happen on more than one accassion.
Old May 29, 2006 | 04:49 PM
Zaairman's Avatar
I've had a Terdonator split in two before, yes it increased airflow that much that the air resistance split it in two.
Old May 29, 2006 | 05:14 PM
PSS-Mag's Avatar
Years ago I had a turd that felt like it split me in two. I now have an appreciation for women giving natural child birth.
Old May 29, 2006 | 06:59 PM
Gearhead99's Avatar
Did the filter actually split open, or blow away from the mounting??
Old May 29, 2006 | 07:11 PM
I don't think Quintin's reply will work here.
