reformatting q-
Old Mar 19, 2006 | 07:05 PM
BalogUK's Avatar
reformatting q-
ok, my 256mb CompactFlash card effed up. cant format it from the digi-cam- it fails and give me the failed to format error msg. so ive put it into the external card reader- and its there, but doesnt show that it is- i can click the drive (E:) properties, and it lists it as a RAW file sytem 0 bytes used, 0 bytes avail. i tell it to format, and it says disk cannot be formatted- i've tried command prompt:
format e: /fs:fat but no luck- how can i get this card back up and running- if i can get it to some file type, then maybe my camera will reformat to the correct format?
Old Mar 19, 2006 | 09:19 PM
ViperGrendal's Avatar
Is the card locked by chance?
Other than that I got nothing.
Maybe go into computer management and see if you can creat a partition on it. I'll have to look at my 32mb CF card.....
Old Mar 19, 2006 | 09:22 PM
Yeah, it won't let me mess with partitions on the flash card. Sorry
Old Mar 19, 2006 | 09:45 PM
BalogUK's Avatar
it doesnt show up as useable, so i cant touch it in comp management.... i get an ioctl error when i try and chkdsk- im trying to work with diskpart right now, but cant get it to pick a drive... if i can make a partition, then i can reformat
Old Mar 20, 2006 | 11:24 AM
vader716's Avatar
Who is the manufacturer
Old Mar 20, 2006 | 12:29 PM
BalogUK's Avatar
its a fujifilm card- i've emailed them, and sandisk asking for the steps to correct failed reformatting- Sandisk lists the steps to correct this problem, but they arent for XP bases- only on lower models, and well xp uses different cmd prompts. fujifilm is willing to send me a new card if i send them mine- i'd like to try and fix it-cause all it really entails is a simple reformatting first before i send it away
Old Mar 20, 2006 | 12:33 PM
vader716's Avatar
what commands dont work for XP?
Old Mar 20, 2006 | 12:38 PM
BalogUK's Avatar
go to start>help and support> search: scandisk the results will showup on the left, click the "new ways to do familiar tasks" it will give you a chart
