Help with a '96 Cougar
Old Feb 20, 2006 | 11:04 AM
MROLDV8's Avatar
Question Help with a '96 Cougar
I don't know where else to post this, but somebody will probably give me the info I need pretty quick.
My wife has a '96 Cougar XR7. She had to turn the 4-way flashers on, and now the turning signals don't work. When the lever is moved there's no clicking & no lights come on...even on the dash. The fuse is OK. If I wiggle the stalk there's still nothing.
I need to know from one of you where the flasher unit is. The owner's manual doesn't give a location & neither does the shop manual on CD. I'm guessing that the flasher is the problem, but I'm not about to tear the whole dash apart looking for it. I know where the 4-way flasher is, cause I can hear it. Is the turning signal flasher one of those old round ones, or is it some other shape? Do the 4-ways and the signals share the same unit?
It's cold outside and my wife refuses to signal with her arm out the window.
Help please.
MR
Old Feb 20, 2006 | 11:31 AM
UrbanCowboy's Avatar
Wish I could help ya bud; but I just don't know. Best of luck!
Old Feb 20, 2006 | 11:39 AM
jamzwayne's Avatar
This maybe a stupid idea, but I'd at least try it if you havent.
Turn the hazzards on and turn one of the turn signals (left ot right) and then turn off the hazzards and see if the turn signal works again. I know sounds retarded, but you never know.
That's the best I have. I wish I was of more help.
BTW...when you have it figured out and fixed, will you post here again, and let us know what it was and how you fixed it?
Old Feb 20, 2006 | 11:46 AM
Don't undersell yourself Jamz; that was a great idea
Old Feb 20, 2006 | 11:47 AM
jamzwayne's Avatar
Puppies now?
Dude, I am gonna have to log off today...or at least until you ..awe hell, nevermind.
Old Feb 20, 2006 | 11:50 AM
J-150's Avatar
the flasher would be close to to the steering wheel. Check just under the dash (where your kees would go). If not there check inside the steering column (probably on the underside of it)
Old Feb 20, 2006 | 11:52 AM
MROLDV8's Avatar
I'll give that a try, thanks. Yea, I'll let you know once I've fixed it. My experience has been that sometimes the signal flasher is on the passenger's side of the dash, but on this car who knows?
MR
Old Feb 20, 2006 | 12:38 PM
Quintin's Avatar
The flasher is mounted near the parking brake pedal assembly. It looks like the older circular style ones, held to the dash with a 7mm bolt or a Phillips head screw, I forget which exactly. It should be yellow or grey, IIRC. But before that, try a shot of brake clean through the hazard switch opening (use some that evaporates on contact) to see if the multifunction switch contacts will free up a bit.
Old Feb 20, 2006 | 12:49 PM
MROLDV8's Avatar
Thanks...I'll try that once I locate some of that type of brakeclean. Would the CRC product work?
MR
Old Feb 20, 2006 | 01:23 PM
6T6CPE's Avatar
Help please.
MR
This happened with my F150. The flasher unit was way up under the dash. But it wasn't the flasher unit. It was the turn signal stalk. I thought it was gonna cost me a fortune but it was much cheaper than I figured.
Old Feb 20, 2006 | 03:39 PM
MROLDV8's Avatar
Thumbs up
Quintin...You da man!!!
I shot some CRC QD electronic cleaner into the 4-way switch, and now everything works.
I thank you & my wife thanks you. Next time you're in the Cincinnati area, stop by my garage for an adult beverage.
MR
Old Feb 20, 2006 | 07:02 PM
Quintin's Avatar
Cool, I love a happy ending.
Old Feb 20, 2006 | 08:00 PM
MROLDV8's Avatar
Thumbs up
For what it's worth, my '92 E150 van has what looks like the same type of 4-way flasher switch as the Cougar. I don't know if the circuitry is the same, or if it's the same for a 90's F-series, but this simple fix is something to keep in our memory banks. Thanks again Quintin.
MR
