Computer Question...
Old Oct 24, 2005 | 04:09 PM
dzervit's Avatar
Originally Posted by UrbanCowboy
Actually, the CPU fan is not spinning. I didnt think they could die like that. It has a large heat sink under the fan as well. Could the lack of a spinning fan really cause the system to lockup within minutes?
Usually not. It's take a CPU a little bit to get fired up and die. You never know though, replace it and see what happens. It's a start.
Old Oct 24, 2005 | 04:26 PM
vader716's Avatar
I've seen some systems run for days with no fan if the heatsync and other fans were working well. I've seen system lock minutes after boot up.
It is a cheap test.
Have I mentioned I hate hardware?
Old Oct 24, 2005 | 04:42 PM
kobiashi's Avatar
Hey Vader . . . just curious. How do you feel about hardware?
(Withour it, ya know, all the software in the world is useless).
Old Oct 24, 2005 | 04:46 PM
vader716's Avatar
Man I hate hardware....
Just like taxes it is a necessary evil....but I hate em.
Pentium this or that....argghh...I hate troubleshooting hardware, I hate replacing it, I hate ordering it, I hate it in general.
Freakin cut my knuckles on it...think you got it fixed and then it locks up...
Arrrgghhhh
Old Oct 24, 2005 | 04:51 PM
kobiashi's Avatar
Arrrgghhhh
Actually, I have no idea what any of y'all are talking about. Such things don't happen when one is protected by Steve's Reality Distortion Field™.
Old Oct 24, 2005 | 05:01 PM
dzervit's Avatar
BWWWAAAAHHHH HAH HAH HA!!!
Hardware rules, software blow since most idiot programmers can't actually program. One big thing I like about Macs, they keep a tight reign on commercial developers. Well, at least they used to!
Old Oct 24, 2005 | 05:06 PM
kobiashi's Avatar
Old Oct 24, 2005 | 05:34 PM
vader716's Avatar
saved and printed....now hangs in my server room.
Old Oct 24, 2005 | 05:45 PM
Kool Aid's Avatar
Yes.
That's why I suggested it.
Old Oct 24, 2005 | 06:11 PM
ViperGrendal's Avatar
Yeah if the heatsink fan isn't running that could cause the problem. It's overheating and locking up. Hopefully it hasn't done any permanent damage. You can take any old fan and position it to blow over the CPU at highest speed and see if that helps if you don't have a fan to put on the heatsink itself.
So, I have a $1 on the CPU overheating. I run an AMD64 and on the stock heatsink if the fan isn't running it's burning itself up. I ahve an aftermarket HS on it now that would take a bit to overheat without the fan.
Old Oct 24, 2005 | 06:19 PM
thereisnospoon's Avatar
ABSOLUTELY
Without a fan and, therefore, a working heatsink, temps can go from 0 to 70 degrees C in a matter of minutes....SECONDS if you have had it on for a while.
Your problem does NOT seem like a motherboard problem - if it was a motherboard problem you would get spontaneous rebooting on startup. If it freezes, it's either memory or processor. If you know your memory is good, then it's the processor.
Since the fan is bad, the likelihood that the non-working fan has caused your processor to fry is almost 100 percent....especially if you left it on for the time period you said you left it on (presumably without the fan working). Looks like you're going to be buying a new processor and fan combo unless your processor is still under warranty (which it probably isn't unless you've had it for less than 6 months time - even then you have to have the factory "tie-fighter" fan on the processor for the manufacturer to accept the claim).
On another note, test another fan in the motherboard fan slot - if a new fan won't power on, then there's damage to the mobo too.
Old Oct 24, 2005 | 06:58 PM
Kool Aid's Avatar
If it's a P-4, it's designed to shut itself off, to prevent killing itself.
AMD's don't have this feature.
Old Oct 24, 2005 | 07:14 PM
dzervit's Avatar
On another note, any decent quality PC build in the last 5+ years has overheat protection... AMD or no AMD..
Old Oct 25, 2005 | 12:18 AM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Yea and thats why I would rather have a P III if I had to seattle for a P.
Old Oct 25, 2005 | 12:49 AM
PSS-Mag's Avatar
If moving air around the processor in some way dosent help, "note I have taken the side of the case off and put a box fan blowing in before to limp along til new heat sink and fan got in." But a last ditch chance to boot it when you know a new processor is on the way.
Enable Bios shadowing
Power up
If it locks up then restart while holding Esc
Run throu shadow test until you reach processor test then hit skip and restart again.
It might, just maybe boot that way. I had a laptop I had to boot like that for a while.
