titan towing better then f1fiddy
Originally Posted by SAJEFFC
^^^faster you mean "8000 pounds" and not "8000 rpm" right?? I dont think they will spin to 8000 rpm's!
lol yeh dont ya hate when u multi task and type something wrong without realising it:-p
Originally Posted by KRConvert
Blasphemy! The Titan is rated up to 9500 lbs, the new F150s are rated up to 9900 lbs. But there is a lot to say about the Titan. I have to admit, Nissan did their homework.
The Titan is the only other truck my wife and I seriously considered before buying on the Ford Family Plan. In the end, pricing and the pleasure of owning a 1999 F150 for the last 6 years with no problems won us out.
My 04 F 150 is rated to tow 8500 Lbs 5.4, 4x4 17 inch wheal 355 LTD slip, long box, this is in the owners manual... For a 18 in wheal, you lose close to 500 lbs in towing, I would dbbl check your Ford oeners manual, I don't recall a seeing a F150 configuration that was rated to tow 9900 lbs.
Lots of blown read ends. Take a look here and have some fun reading time!
http://www.titantalk.com/forums/forumdisplay.php?f=88
This is like arguing about Fruit of the Loom or Hanes for pete's sake. This thread is all about personal opinions on towing and percieved performance. They both tow well, they are both nearly rated the same. Any owner that has to tow 4-tons with an F150 or Titan is retarded for not getting a SD w/ a PS. Buy whatever truck tickles your fancy and ****.
Originally Posted by bamorris2
1) The 5.4 produces 300hp @ 5000 rpm, and 365 lb-ft torque @ 3750rpm... The Titan's 5.6 produces 305hp @ 4900rpm, and 379 lb-ft @ 3600rpm... So the Titan motor makes more hp and more torque, both at lower rpm's than the F150. So, all other things equal (which they're not), yes the Titan would tow better.
For instance:
If the titan's dyno plot looks like this:
_________^-------, it means the power is 'not-there....not-there....not-there...then WHAM!' Think: S2000.
Get it?
This debate AGAIN?
I personally don't care which tows better. The F150 is a MUCH more comfortable vehicle if you spend alot of time behind the wheel. Fords DECADES of experience leads the way year after year. Nissan makes a good truck, but they've got a long way to go before they are truly in Fords league.
Originally Posted by J-150
regular cab with HD suspension (8300# package?) and 4.10 gears.
The truck that no one buys...( But I would ) so it can't be compared to the Titan, The f-150 is more of a work truck, The Titan, SC SCREW F-150 are pretty close in towing...
