Home Network Question
Old Sep 6, 2005 | 12:28 PM
BlueFlareside's Avatar
I have set up a wireless network at my in-laws’ and I am having a problem with file and printer sharing. Both computers are Windows XP and they have a Netgear router (I have the same router). The router is using the 64-bit encryption. I have added my mother-in-law’s laptop to the allow list of the router and I have added her IP address to ZoneAlarm on my father-in-law’s desktop (where the printer is connected to). I have run Network Setup Wizard on both machines and verified that they are both set to MSHOME. The problem is that I still cannot get it to share files or the printer. They both have a Shared Folder set up and the printer is shared on his computer. I had this problem recently with the daughter’s new computer and I thought that I had to add a Service, Client or Protocol under the Properties of the network connection, but I cannot remember how I did it or what I did.
When I look at “My Network Places” on his computer, I can see her computer but it will not allow me to go any further. On her laptop I cannot even see his computer or printer.
Can someone help???
Old Sep 6, 2005 | 12:44 PM
vader716's Avatar
1st - turn off or disable all the firewall including the windows firewall until you have it working then enable them.
Can you ping them?
Try:
Start -->run
\\Ipaddress and hit enter does it list anything?
Old Sep 6, 2005 | 12:46 PM
I will try to ping them. She can get online through the router but just cannot connect to the other computer.
I turned off the Windows XP firewall on both but will try it with Zonealarm off on both.
Old Sep 6, 2005 | 12:52 PM
jamzwayne's Avatar
If all that doesn't work..reboot the network.
Old Sep 6, 2005 | 01:16 PM
Faster150's Avatar
windows firewall is causing the problem. disable all firewalls. and make sure file and print sharing is enabled.
Old Sep 6, 2005 | 01:21 PM
Net Wurker's Avatar
Also, if this is XP Home, the host box needs to have the guest account enabled for file sharing to work, I believe. Not sure if the wizard enables that account or not.
Old Sep 6, 2005 | 01:52 PM
And how do I do that?
Old Sep 6, 2005 | 02:51 PM
countyboy04's Avatar
I have a simliar question. I a tried to set up a network on my desktop and my laptop which is connected through a wireless router. The desktop can see the laptop but the laptop does not see the desktop. What could the problem be?
Old Sep 6, 2005 | 03:11 PM
Net Wurker's Avatar
Control Panel > Users
Make sure the account named "Guest" is enabled. I have heard that this is required on XP Home (for file sharing). I never had Home, so I don't know if it is true or not.
Normally, you want the Guest account disabled for security purposes.
Old Sep 6, 2005 | 03:39 PM
I will try that if all else fails. I did not have to do that at my house, though. I got my daughter's computer to connect to my printer but cannot remember how. It had something to do with the TCP/IP settings.
Old Sep 6, 2005 | 03:46 PM
Net Wurker's Avatar
Make sure you have "File and Print sharing for Microsoft Networks" installed...it will show up under properties of the network card.
Old Sep 6, 2005 | 04:18 PM
It is installed on both of them.
Old Sep 6, 2005 | 04:21 PM
vader716's Avatar
What about the pinging and the start run results.
If the basics aren't in place it'll take 5 pages of "well try this" until you stumble on the answer.
Old Sep 6, 2005 | 04:26 PM
I will have my father-in-law check it tonight while on the phone with him. I am at work at will have to wait until tonight at the earliest.
I just thought that there was one simple setup thing to allow file and printer sharing that I may be missing. Is there a step-by-step for the entire process? I did it at home but it was more trial and error on my home network (and it was over 1 year ago).
Thanks for your help,
Steve
Old Sep 6, 2005 | 06:21 PM
Net Wurker's Avatar
Here is a link to a Microsoft Article on file sharing with XP.....
http://support.microsoft.com/default...b;en-us;304040
