Question for the computer literate
Old Aug 3, 2005 | 05:02 PM
Tbird69's Avatar
Question Question for the computer literate
I'm hoping someone can tell me why I can't download and install Macromedia flash player into my PC. I've gone through the Macromedia support and have done everything they suggest, but it still won't install. help!
Old Aug 3, 2005 | 05:18 PM
dzervit's Avatar
Need more info... at what point does it reject the download/install... what O/S are you using... what browser are you using... blah blah blah...
Old Aug 3, 2005 | 05:52 PM
Peacemaker's Avatar
Mine does the same thing. F' it.
Old Aug 3, 2005 | 06:51 PM
Tbird69's Avatar
I'm using Microsoft XP Professional with Internet Explorer 6.0. The install fails right when I try to download. I click the install button, it moves to the install screen and then won't install. I downloaded the shockwave player with no problems, but the flash player just won't take.
Old Aug 3, 2005 | 07:07 PM
momalle1's Avatar
Try clearing your Internet history, Temporary Internet Files, Temp files before installing. Also, if you you have IE security set too high, that may be preventing installation also.
Old Aug 3, 2005 | 07:31 PM
UrbanCowboy's Avatar
If it makes you feel anybetter, I have the exact same problem. I have up long ago even trying to get it installed.
Old Aug 3, 2005 | 08:17 PM
kingfish51's Avatar
Are you sure you are not downloading the wrong one. There are 2 on the site. One for IE and one for Netscape/Mozilla/Firefox. If you download the one for Mozilla, it will not install for IE.
Old Aug 3, 2005 | 08:24 PM
Tbird69's Avatar
Good question. I just assumed that it was for IE, since it takes me right to the download page. I shall check that.
Old Aug 3, 2005 | 08:32 PM
RockyJSquirrel's Avatar
I never got Macromedia Flash installed either, but here's a fun Shockwave game called 'Snowball Fight'. It's the only reason I have the program on my computer.
http://www.nny.com/holiday/shocked.htm
Old Aug 3, 2005 | 08:35 PM
kingfish51's Avatar
Go to the more players page. That one lists which is which. Don't forget the uninstaller too. If it doesn't work next time run the uninstaller, then try to reinstall.
Old Aug 3, 2005 | 08:37 PM
wrench007's Avatar
Link no workie for me, dang, I wana play.
Old Aug 3, 2005 | 09:09 PM
The professor's Avatar
Hey, RJS that games fun. I could only get to level 3 on it but it's fun
Old Aug 3, 2005 | 09:12 PM
Once you figure out how to make it through all 10 levels, then the next challenge is to make it all the way through without a single casualty.
Hint- move all your guys down to the left corner first, then pick them off one at a time.
Old Aug 3, 2005 | 10:11 PM
vader716's Avatar
Before installing the Flash Player please ensure that you have the following settings correctly set:
Internet Explorer ActiveX settings
Although your browser security settings should be chosen by you or your system Administrator, the 'Medium: Default Level' will allow you to view Macromedia Flash content. For any Custom Level, ensure that both "Download Signed ActiveX controls" and "Run ActiveX controls and plug-ins" are not disabled. (Enable or Prompt will work).
To view your Security Level do the following:
Open Internet Explorer.
Choose Tools then Internet Options.
Select the Security tab.
Choose Internet.
Ensure that "Download Signed ActiveX controls" and "Run ActiveX controls and plug-ins" are not disabled.
If you are having trouble installing make certain that your Internet Explorer security level is not set to High or at a custom level which does not allow viewing of ActiveX controls.
Computer user permissions
User permissions determine whether or not you are allowed to install ActiveX controls or plug-ins. If you don't have Administrator access to your Windows NT, 2000, or XP equipped computer, you may not be able to install the Flash Player successfully. Permissions can be tricky but, in general, you should be able to install and use the Macromedia Flash Player if your system Administrator has provided full access to the Macromed directory (C:\Winnt\System32\Macromed\).
Macintosh OS X users must also have proper access to run the Flash Player on Netscape 6. If you have problems with this configuration, refer to Netscape 6.2 has problems utilizing the Macromedia Flash Player 6 plug-in on OS X (TechNote 16214).
All web browsers must be closed
When installing Flash Player with the standalone installer, all of your web browser windows must be closed. You will also need to close any application that makes any HTTP requests using the browser. Examples of this type of software include but are not limited to weather applications, messenger services, or audio or video media players.
Previous versions of Macromedia Flash Player should be removed
Uninstall any previous version of Flash Player before using the standalone installer. For instructions on removing the player, please see How to uninstall the Macromedia Flash Player plug-in and ActiveX control (TN 14157).
After these settings are in place, you are ready to download and/or install the Flash Player.
Then click this link:
http://www.macromedia.com/go/full_flashplayer_win_ie
Old Aug 4, 2005 | 02:04 PM
tthorn's Avatar
Also make sure you are logged on as an administrator
