I think I've just been hacked.
Old Jun 14, 2005 | 11:04 PM
Net Wurker's Avatar
Damn..sometimes viruses will write a reference to a non-existant ip address to block access to certain sites...not in this case, though.
Old Jun 14, 2005 | 11:06 PM
Quintin's Avatar
Aha!
Didn't copy the whole file. Sorry, ain't too happy right now. How's this:
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
127.0.0.1 www.symantec.com
127.0.0.1 securityresponse.symantec.com
127.0.0.1 symantec.com
127.0.0.1 www.sophos.com
127.0.0.1 sophos.com
127.0.0.1 www.mcafee.com
127.0.0.1 mcafee.com
127.0.0.1 liveupdate.symantecliveupdate.com
127.0.0.1 www.viruslist.com
127.0.0.1 viruslist.com
127.0.0.1 f-secure.com
127.0.0.1 www.f-secure.com
127.0.0.1 kaspersky.com
127.0.0.1 kaspersky-labs.com
127.0.0.1 www.avp.com
127.0.0.1 www.kaspersky.com
127.0.0.1 avp.com
127.0.0.1 www.networkassociates.com
127.0.0.1 networkassociates.com
127.0.0.1 www.lycos-vds.com
127.0.0.1 t35.com
127.0.0.1 www.t35.com
127.0.0.1 t35.net
127.0.0.1 www.t35.net
127.0.0.1 funpic.org
127.0.0.1 www.funpic.org
127.0.0.1 funpic.de
127.0.0.1 www.funpic.de
127.0.0.1 www.ca.com
127.0.0.1 ca.com
127.0.0.1 mast.mcafee.com
127.0.0.1 my-etrust.com
127.0.0.1 www.my-etrust.com
127.0.0.1 download.mcafee.com
127.0.0.1 dispatch.mcafee.com
127.0.0.1 secure.nai.com
127.0.0.1 nai.com
127.0.0.1 www.nai.com
127.0.0.1 update.symantec.com
127.0.0.1 updates.symantec.com
127.0.0.1 us.mcafee.com
127.0.0.1 liveupdate.symantec.com
127.0.0.1 customer.symantec.com
127.0.0.1 rads.mcafee.com
127.0.0.1 trendmicro.com
127.0.0.1 pandasoftware.com
127.0.0.1 www.pandasoftware.com
127.0.0.1 www.trendmicro.com
127.0.0.1 www.grisoft.com
127.0.0.1 www.microsoft.com
127.0.0.1 microsoft.com
127.0.0.1 www.virustotal.com
127.0.0.1 virustotal.com
Old Jun 14, 2005 | 11:07 PM
RockyJSquirrel's Avatar
Quintin,
It's a long shot, but if you post your email addy for a few minutes, I'll download the removal tool and see if I can email it to you. My email will have 'r-j-s' in it.
Old Jun 14, 2005 | 11:08 PM
ViperGrendal's Avatar
try this...
http://www3.ca.com/securityadvisor/virusinfo/scan.aspx
I can't find a demo of their virus scanner, it's the one I use and isn't commonly blocked by viri.
Quintin's Avatar
legendf1 at earthlink dot net
Net Wurker's Avatar
thats it! delete all that crap below the local host line...
Old Jun 14, 2005 | 11:09 PM
bigd999's Avatar
The following instructions pertain to all current and recent Symantec antivirus products, including the Symantec AntiVirus and Norton AntiVirus product lines.
Disable System Restore (Windows Me/XP).
Remove all the entries that the risk added to the hosts file.
Update the virus definitions.
Run a full system scan and delete all the files detected.
Delete any values added to the registry.
Reenable the SharedAccess service (Windows 2000/XP only).
For specific details on each of these steps, read the following instructions.
1. To disable System Restore (Windows Me/XP)
If you are running Windows Me or Windows XP, we recommend that you temporarily turn off System Restore. Windows Me/XP uses this feature, which is enabled by default, to restore the files on your computer in case they become damaged. If a virus, worm, or Trojan infects a computer, System Restore may back up the virus, worm, or Trojan on the computer.
Windows prevents outside programs, including antivirus programs, from modifying System Restore. Therefore, antivirus programs or tools cannot remove threats in the System Restore folder. As a result, System Restore has the potential of restoring an infected file on your computer, even after you have cleaned the infected files from all the other locations.
Also, a virus scan may detect a threat in the System Restore folder even though you have removed the threat.
For instructions on how to turn off System Restore, read your Windows documentation, or one of the following articles:
How to disable or enable Windows Me System Restore
How to turn off or turn on Windows XP System Restore
Note: When you are completely finished with the removal procedure and are satisfied that the threat has been removed, reenable System Restore by following the instructions in the aforementioned documents.
For additional information, and an alternative to disabling Windows Me System Restore, see the Microsoft Knowledge Base article: Antivirus Tools Cannot Clean Infected Files in the _Restore Folder (Article ID: Q263455).
2. To remove all the entries that the risk added to the hosts file
Navigate to the following location:
Windows 95/98/Me:
%Windir%
Windows NT/2000/XP:
%Windir%\System32\drivers\etc
Notes:
The location of the hosts file may vary and some computers may not have this file. There may also be multiple copies of this file in different locations. If the file is not located in these folders, search your disk drives for the hosts file, and then complete the following steps for each instance found.
%Windir% is a variable that refers to the Windows installation folder. By default, this is C:\Windows (Windows 95/98/Me/XP) or C:\Winnt (Windows NT/2000).
Double-click the hosts file.
If necessary, deselect the "Always use this program to open this program" check box.
Scroll through the list of programs and double-click Notepad.
When the file opens, delete all the entries added by the risk. (See the Technical Details section for a complete list of entries.)
Close Notepad and save your changes when prompted.
3. To update the virus definitions
Symantec Security Response fully tests all the virus definitions for quality assurance before they are posted to our servers. There are two ways to obtain the most recent virus definitions:
Running LiveUpdate, which is the easiest way to obtain virus definitions: These virus definitions are posted to the LiveUpdate servers once each week (usually on Wednesdays), unless there is a major virus outbreak. To determine whether definitions for this threat are available by LiveUpdate, refer to the document: Virus Definitions (LiveUpdate).
Downloading the definitions using the Intelligent Updater: The Intelligent Updater virus definitions are posted daily. You should download the definitions from the Symantec Security Response Web site and manually install them. To determine whether definitions for this threat are available by the Intelligent Updater, refer to the document: Virus Definitions (Intelligent Updater).
The latest Intelligent Updater virus definitions can be obtained here: Intelligent Updater virus definitions. For detailed instructions read the document: How to update virus definition files using the Intelligent Updater.
4. To scan for and delete the infected files
Start your Symantec antivirus program and make sure that it is configured to scan all the files.
For Norton AntiVirus consumer products: Read the document: How to configure Norton AntiVirus to scan all files.
For Symantec AntiVirus Enterprise products: Read the document: How to verify that a Symantec Corporate antivirus product is set to scan all files.
Run a full system scan.
If any files are detected, click Delete.
Old Jun 14, 2005 | 11:10 PM
got it, I'll go download the removal tool now. See you in about 15 minutes.
bigd999's Avatar
Important: If your Symantec antivirus product reports that it cannot delete a detected file, Windows may be using the file. To fix this, run the scan in Safe mode. For instructions, read the document: How to start the computer in Safe Mode. Once you have restarted in Safe mode, run the scan again.
After the files are deleted, restart the computer in Normal mode and proceed with the next section.
Warning messages may be displayed when the computer is restarted, since the threat may not be fully removed at this point. You can ignore these messages and click OK. These messages will not appear when the computer is restarted after the removal instructions have been fully completed. The messages displayed may be similar to the following:
Title: [File path]
Message body: Windows cannot find [file name]. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.
5. To delete the value from the registry
Important: Symantec strongly recommends that you back up the registry before making any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify the specified subkeys only. For instructions refer to the document: How to make a backup of the Windows registry.
Click Start > Run.
Type regedit
Click OK.
Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
Navigate to the subkeys:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\RunServices
In the right pane, delete the value:
"WINDOWS SYSTEM" = "winligon.exe"
Exit the Registry Editor.
6. To reenable the SharedAccess service (Windows 2000/XP only)
The SharedAccess service is responsible for maintaining Internet Connection Sharing and the Windows Firewall/Internet Connection Firewall applications in Windows. (The presence and names of these applications vary depending on the operating system and service pack you are using.) To protect your computer and maintain network functionality, re-enable this service if you are using any of these programs.
Windows XP Service Pack 2
If you are running Windows XP with Service Pack 2 and are using the Windows Firewall, the operating system will alert you when the SharedAccess service is stopped, by displaying an alert balloon saying that your Firewall status is unknown. Perform the following steps to ensure that the Windows Firewall is re-enabled:
Click Start > Control Panel.
Double-click the Security Center.
Ensure that the Firewall security essential is marked ON.
Note: If the Firewall security essential is marked on, your Windows Firewall is on and you do not need to continue with these steps.
If the Firewall security essential is not marked on, click the "Recommendations" button.
Under "Recommendations," click Enable Now. A window appears telling you that the Windows Firewall was successfully turned on.
Click Close, and then click OK.
Close the Security Center.
Windows 2000 or Windows XP Service Pack 1 or earlier
Complete the following steps to re-enable the SharedAccess service:
Click Start > Run.
Type services.msc
Then click OK.
Do one of the following:
Windows 2000: Under the Name column, locate the "Internet Connection Sharing (ICS)" service and double-click it.
Windows XP: Under the Named column, locate the "Internet Connection Firewall (ICF) / Internet Connection Sharing (ICS)" service and double-click it.
Under "Startup Type:", select "Automatic" from the drop-down menu.
Under "Service Status:", click the Start button.
Once the service has completed starting, click OK.
Close the Services window.
Old Jun 14, 2005 | 11:11 PM
nix that, I see your host file is listing CA.com in there. You can still try the link since it's a www3.....
Net Wurker's Avatar
If you get rid of those bogus entrys in your host file, the links to symantec will work..then just go hit the web site with the online removal tool.
Old Jun 14, 2005 | 11:12 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Lets try this....
Right click on the actual e-mail.
then got to properties and left click,
then go to details tab at the top and left click,
then go to the message source button at the bottom and left click.
Highlight everything in that window with your curser, then right click and hit copy,
then come here and paste that into a post.
Hopefully there will be a key script in there that I or someone might recognize that will give us a clue to what virus might be inbedded in the attachment. Then once we know what it is I can load the fix onto my server give you a link to the address to go download it from me, the virus wont know to block my servers IP address so you will beable to get the tool from me with no problems. Then you can load the tool and use it and presto bye bye mr. virus guy!
Old Jun 14, 2005 | 11:13 PM
Quintin's Avatar
I deleted all those files below the host thingy, now the online Symantec tool is loading up. Before, it wouldn't download ActiveX to do the online scan, and I couldn't pull Task Manager up to see what the hell was going on.
Old Jun 14, 2005 | 11:15 PM
PSS-
Go to my earlier post where I linked the removal tool. You can download it and host it. I just emailed it to Quintin, hopefully it is email-able.
Old Jun 14, 2005 | 11:16 PM
Quintin's Avatar
The online Symantec virus scan is running right now, when it gets done, I'll try downloading that fix anyways too. I think things are starting to act like they should...
...I've still got a full load of double ought buck for the sorry punk that came up with this.
