What can I do about my digital camera?
Old May 31, 2005 | 12:35 PM
clonetek's Avatar
If all else fails, see if there is a master reset for the camera.
found it:
It says in REC or PLAY mode press [menu]
Select the "set up" tab, select "reset" then press the [->] (arrow button)
Select "reset" then press [Set]
If you still can't get it to work, go get another camera. You'll spend way too much to get the old one repaired.
PS: Buy a Sony camera.
Old May 31, 2005 | 01:13 PM
Ford Lariat's Avatar
I just tinkered around with it.. The EV was set to 0.0 and it was in 'auto' mode. I might go try it outside today and see if it still looks the same. Sometimes the pictures turn out alright, but other times they are 'unacceptable. '
Old Jun 1, 2005 | 03:38 PM
inbred's Avatar
Originally Posted by PSS-Mag
German lens of a Canon.
huh?
