Checking for Limited Slip
Old May 24, 2005 | 09:28 AM
Ponyrider's Avatar
How can I check to see if a '97-2000 4X4 has a limited slip diff. ?
thanks....
Old May 24, 2005 | 01:02 PM
Bartak1's Avatar
Do a nice big burnout. If both tires start smoking, you got LS, if only one does, you got open.
Or just look on the drivers door jam and there is a sticker with all this stuff about your pickup, look for 'Axle" and look under it, there will be a number. Get that number, go to fordf150.net, and there is a place where you can decode that sticker, and you can find your axle number and see what gears it has, and if its LS or not.
And I know if the number is 19 you have 3.55 gears with an open rear end.
Old May 24, 2005 | 01:14 PM
kingfish51's Avatar
If I'm not mistaken, the axle code will be 2 numbers if it is open, ex. '19'. If it is limited slip it will be a letter and a number, ex. 'B9'.
Old May 24, 2005 | 05:15 PM
Quintin's Avatar
Additionally, if you crawl under the truck and look at the toe tag on one of the rear axle cover bolts, it'll show ratio and whether or not it's limited slip. An open differential will read something like "331" or "355" or "373," indicating a regular 3.31, 3.55, or 3.73 gear respectively. Limited slip gearing is identified as "3L31," "3L55," or "3L73."
Old May 24, 2005 | 05:19 PM
EnglishAdam's Avatar
Er, just jack one rear wheel off the ground and try and turn it.
If it turns easy, you have an open diff, if you can't turn it or it's very stiff, you have an lsd.
Old May 25, 2005 | 08:31 AM
Ponyrider's Avatar
Thanks, guys
