Problem Years
Old May 22, 2005 | 05:15 AM
Ponyrider's Avatar
Problem Years
New to the forum and I'm looking to get into a F150. Are there any model years to avoid / search out??
Looking around the '93-95 years...
thanks for any help....
Old May 22, 2005 | 09:51 AM
Ponyrider's Avatar
Did a little research last night and think I discovered a few things.
Looks like '97 was the first year of the "modern" body style. Is that correct?
Looks like I'll be looking for a '97 or '98 model 4X4. I love that body style...
Any problems with these years I should know about or look for when I go shopping.
I'm a life long Ford man, and I need a Truck to go along with my '95 GT and '66 289 coupe Mustangs.
Any help on this will be appreciated !
Old May 22, 2005 | 10:38 AM
paulv107's Avatar
If you get a 97 or 98, make sure that you at least get the V8. The 4.2L V6 had gasket problems in those years causing the engines to blow up.
Old May 23, 2005 | 02:25 AM
wild-mtn-rose's Avatar
Welcome to the site Ponyrider
Yes, the "modern" body style was introduced in '97. I have a 2000 which is essentially the same except my supercab has the 4 doors instead of just the 3 that you get with the 97's & 98's. They're great trucks and I hope you find one you'll be happy with.
Old May 23, 2005 | 02:33 AM
vegastrac's Avatar
I ordered up a '97 as soon as they were available. It is one of the few trucks that I never had problems with. The only difference that I recall between the '97 and '98 was in '98 they moved the tail pipe behind the rear tire instead of in front of it. we had a lot of frosting over in the rear wheel/tire on cold winter days.
Old May 23, 2005 | 07:35 AM
JTDEERE's Avatar
Originally Posted by paulv107
... 97 or 98,... causing the engines to blow up.
GASP, UH OH
Old May 23, 2005 | 10:17 AM
Dad's Hoss's Avatar
Good choice on the '97 or '98. My only advice would be to get a 5.4 L and assure it has a LS Dif.
Good Luck and happy hunting.
Old May 23, 2005 | 10:44 AM
UrbanCowboy's Avatar
Get a 1995/96 with an Inline-6. It'll run forever. That is, unless you really want a V8.
Old May 24, 2005 | 12:50 AM
Ponyrider's Avatar
Thanks, guys!
Old May 24, 2005 | 08:34 AM
Ponyrider's Avatar
Thanks again for the info!
If anyone hears of a one owner '97-'98 4X4 model in the Nashville, TN area, let me know will ya?
Old May 24, 2005 | 09:19 AM
Ponyrider's Avatar
When you speak of the LS diff. do you mean the rear gears? And why LS?
Is it a better ratio or something?
Old May 24, 2005 | 09:25 AM
Ponyrider's Avatar
I think I figured out what you meant... LS = limited slip, not a chassis package.
