LED flashlight ??
Old May 14, 2005 | 11:21 PM
YOMAN's Avatar
LED flashlight ??
HI there..
I m looking for good quialty LED flashlight that size similar to MAGLITE 3 C or D cells or the small with powerful brigther LED.
ANy recommend??
I m looking to spend UNDER $40-50ish
Thanks!
YOMAN!
Old May 15, 2005 | 02:12 AM
inbred's Avatar
As Art Bell and George always say, check out C Crane...
http://www.ccrane.com
Old May 15, 2005 | 03:51 AM
HHIFX4's Avatar
i use a StreamLight, it is pretty awsome and definatley bright. www.streamlight.com
Old May 15, 2005 | 12:49 PM
YOMAN's Avatar
Cool thanks...
There are too many models of StreamLight flashlights...please help me to pick correct one what i need it.
I m looking for good short-mid range, and not LONGER/far range.
You know to look under the truck, look at engine bay and truck bed, walk thru hiking/trails during at night.
Also i want good last-longer battery, not just regular battery C or D cells.
Thanks!
YOMAN!
Old May 15, 2005 | 05:48 PM
Faster150's Avatar
my brother and dad both have stream lights... my brother bougt one before he went to iraq and it has lasted two years so far on his side pouch it lasted a year at war and is still holding up through all the feild manuvers and so forth... so streamlight is the way to go
Old May 15, 2005 | 08:38 PM
Gearhead99's Avatar
Bought a pretty good one from the Snap-On man.
Small, compact and bright.
Old May 15, 2005 | 09:42 PM
HHIFX4's Avatar
here ya go http://www.copquest.com/10-7000.htm
Old May 15, 2005 | 09:57 PM
Fritzthecat's Avatar
Nothing better than a Maglite. Buy the 3D cell one and add a Luxeonstar LED bulb.
http://www.luxeonstar.com/item.php?i...78&partno=TLE6
I have one and it's very nice. The beam pattern is a little weird (like a butterfly) but the light is pure white and very bright.
Fritz
Old May 15, 2005 | 10:46 PM
MikeF150's Avatar
YOMAN... you might want to check out this site on flashlight reviews - http://www.flashlightreviews.com/index1.html Look at the "reviews" section....
I bought one of the Brinkman Maxfire LX lights - incandescent lithium - $19.99 @ Walmart.... I then bought a dozen of the Surefire 123A batteries $15/dozen).... this thing is great for the price !!! Very bright and worth every penny!
The info on that sire is pretty detailed... never knew anyone could be into flash lights so much.....
Old May 16, 2005 | 12:37 PM
J-150's Avatar
also try www.mec.ca
Mountain Equipment Co-op has some really kewl camping/biking/hiking/climbing stuff. They have stores and do mail order as well.
Any store branded merchandise (MEC brand) is as good if not better than the brand names are. Its a case where you are actually paying for quality.
Old May 16, 2005 | 07:01 PM
bigsherm77's Avatar
I have a Inova mini flashlight that has 5 led bulbs and takes 123A lithium batteries that seem to last forever. The light is very white but only useful for very short distances or very dark areas. It is also a very inexpesive light. For most uses, I've given up on the LED's. I have a Streamlight and a Surefire that I use 99% of the time and they are both great lights. The Surfire works better but the streamlight has a more convenient tail switch. They are both rechargable but are much more expensive. If your just looking for something to say, look under the hood at night or look around a toolshed the LED should do fine. If you plan on using the light outside, even at night, you might want to look for a different (halogen or xenon) bulb.
edit: I also have the inova one LED keychain light which can be had for about 7 bucks and I feel is a must have. That way you always have some kind of light with you in any situation.
websites like www.galls.com should have a pretty good selection.
Old May 16, 2005 | 07:19 PM
dean1614's Avatar
streamlight stinger, comes with a house and vehicle charger for about $80 its available in aluminum or a composite. I have been using one for about 10 years, 15000 candle power @ 1 1/2 continous burn time. comes with extra bulb in the tail cap. switch has a lifetime guarantee
