Drywall guys.. Pointers
Old May 12, 2005 | 09:58 AM
SEU1's Avatar
Second layer of mud went on last night. I was a little worried about my first coat but, after some sanding it came out pretty darn nice.
Thanks again guys !
Old May 12, 2005 | 10:01 AM
jamzwayne's Avatar
Good deal. It's a lot of work, but the outcome is a great feeling.
Old May 16, 2005 | 11:31 AM
SEU1's Avatar
Some pics of the work.
https://www.f150online.com/galleries....cfm?gnum=5865
Old May 16, 2005 | 12:07 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
It looks great SUE1.
I see you already had a stomped ceiling.
I can understand why you wouldn't want to mess that up but, don't you have an exposed crack all the way around where the wall meets the ceiling?
It's hard to tell from the pic but it doesn't look like it was taped there.
At least you have a papered machine edge all the way around the top.
Old May 16, 2005 | 12:26 PM
BROTHERDAVE's Avatar
25 Year Member
i had a corian sink installed and blended to the counter tops and the guy that did it took a cheap 24 or 18" box fan, and a cheap air conditioning filter, turned on the fan, it sucked the filter to it and when he sanded it made little if any mess of my house.
like everyone is saying, the pros need little if any sandpaper.
Old May 16, 2005 | 12:45 PM
SEU1's Avatar
Raoul,
Crown molding is going up around the ceiling....... Hence why the crack is still there..... About 20 more hours of work and I can wrap this puppy up...
It's really cutting into my play time. Plus you should see my truck. It's filthy
Old May 16, 2005 | 12:54 PM
Raoul's Avatar
25 Year Member
Originally Posted by SEU1
Raoul,
That's the construction trade.
Good hangers cover up bad framers.
Good tapers and finshers cover up bad hangers.
Good painters cover up bad tapers and finishers...
...and the trim man makes everybody look good.
Old May 16, 2005 | 01:00 PM
SEU1's Avatar
You bet your azz !!!
Old May 17, 2005 | 12:09 AM
silversvt04's Avatar
Hope this helps
One idea that can keep the dust down ,, use a damp spong and rub the dry drywall filler like waxing gently. the water rehydrates and smooths out the filler. Works as a interm step to minamize the sanding can almost lead to a passable paint ready finish.
Works best on unpainted surfaces as the sponge will pull the filler off a finished surface at the edges.
Done this in the past in radio rooms and eye surgery clinic where we could not remove or dust up equipment.
Russell
Deka construction.
Fastest tool box in town,
2004 lightning
