Loctite
Re: Loctite
Originally posted by Jeff51
If I have to remove the bolt that i put red loctite on, how do I do it?
SL
According to Loctite, heat is required to loosen fasteners after the red is applied. Just for the record, I've used nothing but red on anything, and have never had to use heat to break them loose. They were tight, and cracked loose like a main bearing cap bolt on an old motor, but not tight enough to require heat.
SL
SL
