Printer driver question
Question for the super PC experts. I know a little, but have not found this answer.
I have an HP laser printer. It has available 3 different drivers, PCL6, PCL5E, and Postscript.
What are the differences?
What should I be using?
I am currently using the PCL6 with no problems, but don't know if the others are better.
I think for most people you can use either of the three and never notice the difference...
We have an HP here that has PCL 5C drivers as well as the post script drivers, and I never use the same one all the time, just pick one, always comes out the same.
I would just stick the ones you are using now. Its not going to improve image quality by using different drivers (although, maybe it gives you some different options???)
Gennerally speaking choose the PCL drivers. PCL drivers were written by HP for their printers. They have been upgraded over the years...PCL3, 5, 6, etc. Generally they add new features and printer controls with each version.
Postscript drivers were developed by Adobe and are generally more compatible with other printers. They are preferred for heavy graphic usage.
In general I would suggest you stick with the PCL drivers unless you find a specific need for the PS drivers.
Quark and Multi-Ad also use post script as well. Unless your doing a lot of printing where you either have several different types of graphics layered on one document. Or if you need to print documnets bigger than your media and need to utilize bleed for pre press composition where you have to have them centered for the camera, then the ones you have are fine.
Thanks all for the info.
Right now I have all of them installed as seperate printers, even though there is only 1, and am trying them out. Most of my printing at home is web pages, PDF files, and labels. I'll see how each does and keep the best. Or as long as there are no conflicts, keep them all, and use what is best for each situation.
I did finally find a couple of web sites that explained a little, and they stated that for printers that have things like a duplexer, which mine does, the postscipt fits the bill better. We'll see.
