****ing Codes
Old Mar 17, 2005 | 08:03 PM
Fast Gator's Avatar
****ing Codes
First off..........My Lightning is running like a top
I bought a 97 Explorer for a work car. Popped a bunch of codes tonight............
Can anybody help a brother out????????
PO 715
PO 733
PO 734
PO 741
P 1000
and yeah the friggin O/D light is blinking like Robs eye after a bong hit him square in the face
Old Mar 17, 2005 | 08:21 PM
RockyJSquirrel's Avatar
P0715 turbine Shaft Speed Sensor Circuit fault
P0733 Improper ratio for third gear
P0734 Improper ratio for fourth gear
P0741 TCC System Improper Mechanical Performance
P1000 OBD II monitor testing incomplete
Old Mar 17, 2005 | 08:23 PM
Fast Gator's Avatar
THANK YOU
Now any idea wtf that means to me and what iam dealing with $$$ wise
Old Mar 17, 2005 | 08:27 PM
I have no frigging clue what the codes mean, but here's a good place to start looking.
http://www.obdii.com/obdii.html
Old Mar 17, 2005 | 08:36 PM
Fast Gator's Avatar
Ford Motor Company Driving Cycle
Description of OBDII Drive Cycle
The following procedure is designed to execute and complete the OBDII monitors and to clear the Ford P1000, I/M readiness code. To complete a specific monitor for repair verification, follow steps 1 through 4, then continue with the step described by the appropriate monitor found under the "OBDII Monitor Exercised" column. When the ambient air temperature is outside 4.4 to 37.8°C (40 to 100° F), or the altitude is above 2438 meters (8000 feet), the EVAP monitor will not run. If the P1000 code must be cleared in these conditions, the PCM must detect them once (twice on some applications) before the EVAP monitor can be "bypassed" and the P1000 cleared. The Evap "bypassing" procedure is described in the following drive cycle.
The OBDII Drive Cycle will be performed using a scan tool. Consult the instruction manual for each described function. NOTE: A detailed description of a Powertrain Control Module (PCM) Reset is found in this section, refer to the table of contents.
Drive Cycle Recommendations:
Most OBDII monitors will complete more readily using a "steady foot" driving style during cruise or acceleration modes. Operating the throttle in a "smooth" fashion will minimize the time required for monitor completion.
Fuel tank level should be between 1/2 and 3/4 fill with 3/4 fill being the most desirable.
The Evaporative Monitor can only operate during the first 30 minutes of engine operation. When executing the procedure for this monitor, stay in part throttle mode and drive in a smooth fashion to minimize "fuel slosh".
WARNING
STRICT OBSERVANCE OF POSTED SPEED LIMITS AND ATTENTION TO DRIVING CONDITIONS ARE MANDATORY WHEN PROCEEDING THROUGH THE FOLLOWING DRIVE CYCLES.
For best results, follow each of the following steps as accurately as possible:
OBDII Monitor
Exercised Drive Cycle Procedure
Purpose of
Drive Cycle
Preparation 1. Install scan tool. Turn key on with the engine off. Cycle key off, then on. Select appropriate Vehicle & Engine qualifier. Clear all DTC's/ Perform a PCM Reset. Bypasses engine soak timer. Resets OBDII Monitor status.
2. Begin to monitor the following PIDs: ECT, EVAPDC, FLI (if available) and TP MODE.
Start vehicle WITHOUT returning to Key Off.
3. Idle vehicle for 15 seconds. Drive at 64 Km/h (40 MPH) until ECT is at least 76.7°C (170° F).
Prep for Monitor Entry 4. Is IAT within 4.4 to 37.8°C (40 to 100° F)? If Not, complete the following steps but, note that step 14 will be required to "bypass " the Evap monitor and clear the P1000. Engine warm-up and provide IAT input to the PCM.
HEGO 5. Cruise at 64 Km/h (40 MPH) for up to 4 minutes. Executes the HEGO monitor.
EVAP 6. Cruise at 72 to 104 Km/h (45 to 65 MPH) for 10 minutes (avoid sharp turns and hills) Note, to initiate the monitor: TP MODE should =PT, EVAPDC must be >75%, and FLI must be between 15 and 85% Executes the EVAP Monitor (If IAT is within 4.4 to 37.8° (40 to 100°F))
Catalyst 7. Drive in stop and go traffic conditions. Include five different constant cruise speeds, ranging from 40 to 72 Km/h (25 to 45 MPH) over a 10 minute period. Executes the Catalyst Monitor.
EGR 8. From a stop, accelerate to 72 Km/h (45 MPH) at 1/2 to 3/4 throttle. Repeat 3 times. Executes the EGR Monitor.
SEC AIR/CCM (Engine) 9. Bring the vehicle to a stop. Idle with transmission in drive (neutral for M/T) for 2 minutes. Executes the ISC portion of the CCM.
CCM (Trans) 10. For M/T, accelerate from 0 to 80 Km/h (o to 50 MPH), continue to step 11. For A/T, from a stop and in overdrive, moderately accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop vehicle and repeat without overdrive to 64 Km/h (40 MPH) cruising for at least 30 seconds. While at 64 Km/h (40 MPH) , activate overdrive and accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop for at least 20 seconds and repeat step 10 five times. Executes the transmission portion of the CCM.
Misfire & Fuel Monitors 11. From a stop, accelerate to 104 Km/h (65 MPH). Decelerate at closed throttle until 64 Km/h (40 MPH) (no brakes). Repeat this 3 times. Allows learning for the misfire monitor.
Thanks again
Old Mar 17, 2005 | 08:37 PM
Fast Gator's Avatar
Readiness Check 12. Access the ON-Board System Readiness (OBDII monitor status) function on the scan tool. Determine whether all non-continuous monitors have completed. If not, go to step 13. Determines if any monitor has not completed.
Pending Code Check and Evap Monitor "Bypass" Check 13. With the scan tool, check for pending codes. Conduct normal repair procedures for any pending code concern. Otherwise, rerun any incomplete monitor.
Note: if the EVAP monitor is not complete AND IAT was out of the 4.4 to 37.8° C (40 to 100° F) temperature range in step #4, or the altitude is over 2438 m. (8000 ft.), the Evap "bypass" procedure must be followed.
Proceed to step 14. Determines if a pending code is preventing the clearing of P1000.
Evap Monitor "Bypass" 14. Park vehicle for a minimum of 8 hours. Repeat steps 2 through 12. DO NOT REPEAT STEP 1. Allow the "bypass" counter to increment to two.
Old Mar 17, 2005 | 08:44 PM
bglanden's Avatar
Gator,
What no woo-hoo!! That looked alot like Rob's post's!!LOL!! I think you've gone to the other side and gave up the hops for some of that wacky weed!!
Sorry I won't be able to meet you and Rob at SSOTN on the 16th, but I might bring some Ganja back for Rob, doubt you would like the beer!! Damn Red Stripe!!
Bryan
Old Mar 18, 2005 | 06:43 AM
Shouldn't this have been moved to the 'Engines' forum instead of General? This isn't just chit-chat, it's engine diagnostics.
Old Mar 18, 2005 | 12:22 PM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
But it's not a truck so it fits here I think..
As long as we are on Explorers the high mount brake light is out on my wifes 96 apperently 96-98 they used either neon or floresent bulbs for an experiment with quicker reaction time. But replacment is a Biatch. First if it is the bulb then you have to buy the entire lens/trim/bulb (it is all one piece) that goes all the way across the rear hatch $300 & it's a D.I.O. which requires drilling the pop rivets out that hold it all in place. If it's the balast it's $50 and it's a D.I.O. too.
Screw all of that does anyone know where a led aftermarket replacement might be. I'll gladly pay the $350- $400 for LED and not have to worry about it again.
Old Mar 18, 2005 | 01:06 PM
clonetek's Avatar
crack it open and put a regular bulb in it. save $300!
Old Mar 18, 2005 | 01:11 PM
PSS-Mag's Avatar
The thought had crossed my mind to drill the pop rivets to get it on the bench and go after it with the Dremel.
