Welding help
Welding help
Not exactly automotive related but I'm wanting to get a welder to fix some broken welds on a pipe and cable fence. What type of welder should I get that's in a beer budget? Would something like a Lincoln Electric AC/DC 225/125 do the job? Model K1297 I believe. Or do I need an ARC welder? Help a newbie out. Looking for something that will do the job but also be all purpose if possible.
Check out the message forums:
http://www.hobartwelders.com/mboard/
The majority vote over there is the bigger the better, even if you have to save up.
I'm going with a Hobart 180, it's about $550-$600+ on ebay with free shipping. 220v machine.
If your thinking of getting a 110v machine because you can use it in most outlets, be advised most recommend a min. 20 amp outlet, most house outlets are only 15 amp. So you going to have less draw on already not so powerfull machine which isn't good. Just something to keep in mind.
From what you say you need, that would definately be sufficient, as long as you know how to weld using a stick welder. A little advice though, get the good welding rods. The cheap ones probably will leave nasty looking marks on the metal. I assume you have some experience welding?
wookie, its not a good idea welding in an unventilated area ever. Especially when using welding rods. The rods contain manganese which can be extremely dangerous when breathing in large amounts. Even deadly.
