Garbage disposal leaking...
Old Nov 16, 2004 | 09:00 PM
JD's Avatar
JD
From: Las Vegas, Nevada (originally from Kearny, New Jersey)
...made a mess under the sink. Looks like it is pitted on the sides, a steady stream passess thru when turning the water on. Has anyone ever gone through this, have the unit basically rust out?
Old Nov 16, 2004 | 10:15 PM
Yankee7985's Avatar
Yes, they will basically rot. Most of the cases are made from cast aluminum, which will corrode over the years. Go ahead and drop $125.00 and get a new one. Remember to turn off the power before you work on it. Easy replacement.
