Torque...How do you say it?
Old Sep 7, 2004 | 06:41 AM
MROLDV8's Avatar
Question Torque...How do you say it?
For as long as I can remember, torque was always refered-to in 'foot-pounds'. Now, every time I see a torque rating it's in 'pound-feet'.
Did something change while I was sleeping?
Is there a difference in the way torque is measured?
Is this PC run amuck?
Anybody have an answer?
MR
Old Sep 7, 2004 | 07:54 AM
JohnAndDar's Avatar
I've always said "foot-pounds", but it seems that either way may be used. From encyclopedia.com
torque
Related: Physics
in physics, that which tends to change the rate of rotation of a body; also called the moment of force . The torque produced by rotating parts of an electric motor or internal-combustion engine is often used as a measure of its ability to do useful work. The magnitude of the torque acting on a body is equal to the product of the force acting on the body and the distance from its point of application to the axis around which the body is free to rotate. Only the component of the force lying in the plane of rotation and perpendicular to the radius from the axis of rotation to the point of application contributes to the torque. This radius is called the moment arm, or lever arm. The net torque acting on a body is always equal to the product of the body's moment of inertia about its axis of rotation and its observed angular acceleration . If a body undergoes no angular acceleration, there is no net torque acting on it. Units of torque are units of force multiplied by units of distance, e.g., newton-meters, dyne-centimeters, and foot-pounds (or pound-feet).
Old Sep 7, 2004 | 08:20 AM
EddyG88's Avatar
The two terms are interchangeable because foot and pound are both in the numerator of the units (unlike meters/second). Okay sorry bout the engineering talk...back to my calculator and hole in the wall.
Old Sep 7, 2004 | 12:32 PM
01 XLT Sport's Avatar
Just what EddyG88 stated which is either term is correct. You can state it as ft-lb or lb-ft and it means the same thing.
Put 1lb or weight out to 1 foot and you have 1 ft-lb or 1 lb-ft because its still 1 pound of weight at a 1 foot distance…
Old Sep 7, 2004 | 01:28 PM
PhillipSVT's Avatar
like salvage value and residual value
Old Sep 7, 2004 | 02:19 PM
flanaganman's Avatar
junk yard or salvage yard?
Old Sep 7, 2004 | 02:42 PM
F150Europe's Avatar
Talking
We say Koppel when we mean torque and the unit is Nm. (Newton meter)
Old Sep 7, 2004 | 03:39 PM
PhillipSVT's Avatar
do you also use "kip" as a unit of measure?
Old Sep 7, 2004 | 03:54 PM
Jordan not Mike's Avatar
In strict engineering terms:
Linear work is usually expressed as “foot pounds” of work.
Rotational work (torque) is usually expressed at “pound feet”.
The SAE generally - but not always - classifies torque as "pound-feet" when referring to engine output, as this is rotational.
Note that the terms aren't strictly interchangeable based on the plurality/singularity of the terms.
But in gerneral laymen's terms, they are often used interchangeably.
Old Sep 7, 2004 | 04:08 PM
Ford Lariat's Avatar
I just say "tork."
Old Sep 7, 2004 | 04:20 PM
EnglishAdam's Avatar
Chicken Power
Old Sep 7, 2004 | 06:21 PM
Fast Gator's Avatar
I don't care how you say it, I know I got 589 of them at my back tires
Old Sep 7, 2004 | 06:48 PM
Odin's Wrath's Avatar
Re: Torque...How do you say it?
Titty-Twister.
Old Sep 7, 2004 | 06:58 PM
Fast Gator's Avatar
That reminds me the definition of torque.............
Thats when you wake up with a **** ****-on and push it down to aim.........
Your heels come off the ground
Old Sep 7, 2004 | 09:07 PM
MROLDV8's Avatar
This sounds like the answer I was after. After saying "foot pounds" for so many years, it will be hard to break the habit.
Thanks for all the answers guys.
MR
