Aluminum Welding
always "push" the aluminum gun, don't drag it toward you, you must keep the argon shield in front of the weld, to clean the aluminum in front of you as you go. for thin alum stock like you are welding, you should try some .023" 4043, it would be easier to control the burn-thru
