level of fuel in tank
i have a 25 gallon tank and i put 24.8 in it the other day...it was cool cause hte gas gauge was sittin on the red line, however i stopped grinning when i saw the $42.50 that it cost me
I generally hit the gas station about the time the needle is on top of that arrow, which usally means about $33.
Originally posted by Banshee2000
i wonder that i could only do 60 litres in the tank if the tank clock show me 1/4
That's because of the gasfumes, I guess.
It is a real pain in the s to fill it up with the last 8 liters, it takes forever.
I was wondering if you stop pumping when the pump shuts off for the first time.
If you do it means you can fill up a lot more, the tank isn't full yet.
The fuel gauge won't show that.
Watch the gauge when you are driving with a really full tank.
It takes some time for the needle goes down.
What I am trying to say is, the gauge may show your tank is full but you can add a lot more fuel to it.
$33 for a full tank and you have a bad feeling about that!!!!
Topping-off Tip...
When the gas pump shuts off and you want to keep pumping, try squeezing the trigger only halfway, or maybe a little less. it'll pump slower than normal, but it won't keep clicking off a dozen times and drive you crazy
Re: Topping-off Tip...
It takes forever to fill up all the way.
Re: Re: Topping-off Tip...
Originally posted by F150Europe
Yeah, I am doing that but it will still shut off.
I used to go to Citgo all the time, and theirs weren't as bad.
I've found that the stations that have old dispeners work best, they go A LOT slower so there isn't the 'bottleneck' of gas in the neck.
New, fancy, fast pumps are the worst - it also helps if someone else is using the other dispenser.
What helps sometimes is to keep the pistol (is it called that way, I wouldn't know?
) in a different position so that the flow is in line with the filler tube.
I was wondering, can you guys lock the trigger so that it pumps gas automatically or do you have to squeeze the trigger all the time.
You usually could do that but not anymore.
