need help w/ my bros jeep cherokee
Old Mar 18, 2004 | 10:57 AM
Spaceman Spiff's Avatar
my bros jeep cherokee shakes violently, need help
he says it drives fine on the highway until he hits a bump/hole, then it starts shaking violently. does anyone know what might possibly be the problem, or have any ideas of what to check?
thank you for your help.
Old Mar 18, 2004 | 11:44 AM
clonetek's Avatar
Check the front end suspension.. ball joints, shocks, springs, control arms, etc...
Old Mar 18, 2004 | 07:48 PM
justusinfla's Avatar
try this...
It takes two people to do this but quick , easy and effective for all except ball joints.
It probably has power steering, so one person starts the vehicle in park (or outta gear, brake on!) and rocks the steering wheel back and forth while the other person lays down in front of the vehicle and watches the front end parts for slop/wear, etc. (not recommended if the x-wife is behind the wheel!)
Any loose or worn parts will show up pretty quickly.
And Clone? If I have to see that Hooter girl by the rr fender once more, I swear I'm gonna have to track her down!
Just don't tell her or my wife, ok?
My Gawd, do her legs EVER stop??!
Old Mar 18, 2004 | 10:34 PM
Pickup Man's Avatar
Also, jack up the front wheels (one at a time), and shake them from side to side and top to bottom while you have someone look at the wheel bearings to make sure that they aren't shot.
Old Mar 19, 2004 | 08:02 AM
PBCrisis's Avatar
balance the tires
I used to drive a f-350 tow truck that did the same thing. Shaking was so bad that it was hard to stop the thing safely. Turned out the be the wheels needed balancing.
Stan
Old Mar 19, 2004 | 10:18 AM
93_Snake's Avatar
Tell him to sell it and buy a FORD!!!!!
Old Mar 19, 2004 | 05:18 PM
he got the front tires balanced, said it took alot of weight, but it didnt make a difference. they were going to balance the rear tires too, but he had to leave. we will check the suspension and wheel bearings, too. thanks for all the responses!
93_snake:
i tried to talk him into buying one. he actually got rid of a dakota for the jeep, so which is worse?
