Check out this Drag Racing game
Old Jan 31, 2004 | 09:43 AM
ShaneMcKenna203's Avatar
Drag Racer V2
Push Play, then cheat mode. You can buy any car and go to a store and get parts for it. My best time is 10.32 with a Supercharged GT40 (no nitrous) Try it out. Post your best times.
Shane
Old Jan 31, 2004 | 10:09 AM
broken's Avatar
sweet game, my best os 8:24 no nos with a barracuda
cheers
Broken
http://www.CustomTiRings.com
Old Feb 3, 2004 | 10:27 AM
Why am I only able to run 15.08 in a Cobra? Try running one stock, why is it in the 15's? It's horsepower is only rated at 240, it must not be an 03. And 15.04 in a 700 horsepower Dodge Charger? Man I am not doing too good. After I go to the shop and buy a blower I can run 10's. I dont know why some of these arent faster stock. What are your best times?
Shane
Old Feb 3, 2004 | 03:22 PM
Silverstrike's Avatar
I pulled off a 9.56 @ 142mph, in a Comet w/Drag Radials
Old Feb 3, 2004 | 05:10 PM
ViperGrendal's Avatar
Is 483mph in a Mini Cooper on a 12000m track too fast?
Old Feb 4, 2004 | 12:51 AM
ok, that game was a little too adictive to me. I figured out how to get a civic to do a 4.42 on the 400m.
Old Feb 5, 2004 | 09:03 AM
WOW, I just ran 9.04 in a stock Comet. Those things are quick hah? Can anyone run an 8 stock in a Comet? Try it out, it is really adictive.
Shane
Old Feb 5, 2004 | 10:06 AM
I don't think 8 is possible stock, maybe high 8's.
edit: ok, I just got an 8:48
Old Feb 5, 2004 | 10:41 AM
I cant even get an 8.9 stock... my best is 9.04, how did you get the 8.48 stock? edit: just ran a 9.00
Shane
Old Feb 5, 2004 | 10:43 AM
Do you shift into 5th? You have to right? And you shift after redline right, just before it bounces off the limiter?
Old Feb 5, 2004 | 11:18 AM
If you go into the tuning section you can change the gear ratios. I set it up so I only had to use 2,3 and 4 where 2 is normal 3 a touch above that and 4 a touch above 3. When I hit the end of the track it is almost topped out in 4th.
I think it is when you run all three race styles (in cheat mode) you can go to the store and get the weight reduction clear down to 100 pounds after that. Before running the races it will only go to 1000. That's how I was getting as low as 4:42.
The 8:48 on the comet was bone stock just changing the gear ratios. Also, when you start the race you can shift gears before the light goes green. Just don't hit the accelerator.
Old Feb 5, 2004 | 11:20 AM
I just ran a 8:52 without touching the gear ratio. I'll take a loot at it. Is the comet the fastest car on there stock?
Old Feb 5, 2004 | 11:31 AM
uhhhhh, no idea. I haven't played with it too much stock.
Old Feb 5, 2004 | 02:26 PM
Aha!! I just figured out you can shift with the up arrow key!!
What's your best time??
Old Mar 22, 2004 | 04:35 PM
cfj_uk2k4's Avatar
drag racer v2
hi, i have just started playing and cannot got my cars weight below 1000. i cant find a car to beat the first level in story mode because they are all too heavy. vipergrendal has said you need to play all three modes in cheat mode but i dont know which modes he is on about and if it includes story mode i cant do it until the weight is lower. Please can someone help?
