WTB: Floor Jack, Stands, Oil Change equipment
Old Jan 4, 2004 | 11:32 PM
Flytrap's Avatar
Help me spend my money! (Floor jack, stands, etc...)
Hello, all:
It's been a while since I posted. I hope everyone had happy holidays. I'm looking to blow some Christmas loot on a new jack, some stands and chocks, and some oil change stuff (drip pan, filter wrench). Help me spend my money! What should I look for in these areas, and where should I shop? Thanks, everyone.
James
Old Jan 5, 2004 | 04:20 PM
ChiDiver's Avatar
Try Pep Boys/AutoZone/Murray's for a pair of ramps. They run $25-$30 and are easier to use(usually) than a jack and stands. Those stores carry drain pans and oil filter wrenches too. Same stores carry jack stands for $25-$30.
Downside to ramps is on a very smooth surface they have a tendency to slide away until the tire is on top. A plus is that they are sometimes more convenient when you are working underneath and regular stands would be in the way.
Old Jan 5, 2004 | 06:07 PM
captainoblivious's Avatar
Get Rhino ramps! They are great and easy for oil changes.
Also make sure you get an oil catch pan, preferably one with a nozzle to poor the oil out of. Also, I'd suggest getting gas container to put the oil in from the catch pan. It will make transporting the oil to a dropoff place extremely easy and mess free since the gas pan will be more sealed then an oil catch pan.
You don't need a jack for changing the oil though, but if you want one don't skimp out on it, these trucks are heavy. I've already killed a an MVP 3 ton jack. I refuse to use bottleneck jacks. Right now I'm running the Sears black floor jack that goes for $100 and comes with 2 stands. Only problem is weighs a ton.
Old Jan 6, 2004 | 01:50 AM
Blue Ox's Avatar
Go to sears!!
I just got a craftsman setup from my parents for christmas. It has a 3 ton hydraulic floor jack, two jack stands, two steel wheel chocks, a rolling padded stool, a 4-way lug wrench, jumper cables, and a magnetic protective mat. It was on sale for $99.00 before christmas, but I don't know if it is still so. It is an awesome set up and I have already put it to good use on my wifes corolla when I needed to change the oil.
Check it out here
Craftsman
There are probably better deals out there, but I am happy.
Ox
Old Jan 7, 2004 | 08:04 AM
Flytrap's Avatar
Thanks, everyone...
I found a 3-1/2 ton Craftsman Professional Hydro. Jack and Stands on sale for $99 at Sears and got that. I saw the one Blue Ox got, but I figured I could get my own creeper. I would rather have a little more confidence in the things holding up the truck. captainoblivious, is this the one you have? It is heavy.
Here's the jack I bought.
I also bought some chocks they had there for $7/pair. This jack seems large to me. That's okay because it'll stay in the garage or on the driveway. It also has Speedy-Lift, which means it meets the chassis on the first pump.
I'll check out rhino ramps, too. Can't have enough truck toys...
I used my father-in-laws ramps last time I changed the oil, and I almost drove over them because they kept sliding on his garage floor. Do the Rhino's stick better?
Thanks again.
James
Old Jan 7, 2004 | 08:39 AM
closer9's Avatar
Just curious, have you changed oil on your truck before? I've never needed a jack for anything under my truck, but then I don't care for creepers either... My only suggestions would be to get a fumoto drain valve, an oil pan and a clamping metal band wrench. That's all I use...
and I've had a set of heavy duty ramps for over ten years, and never once used them...
