Code for Keypad ?????????
Old Oct 18, 2003 | 09:42 AM
rajuncajun37's Avatar
Just bought a Excursion , no manual and no code to open truck using keypad.
Where can I find it, 2000 model,.
Thanks for your support,,,,,,,,
Mark Keller
Old Oct 18, 2003 | 12:04 PM
Fast Gator's Avatar
Look up under the dash, drivers side, there a white box. Its between the steering column and the door post. Its got a 5 digit number on it. Thats your code
Old Oct 18, 2003 | 02:27 PM
Swofford's Avatar
You are correct SIR!
Old Oct 18, 2003 | 09:10 PM
Can't find a white box w/ a 5 digit code between the steering and door
Old Oct 19, 2003 | 10:34 AM
Fast Gator's Avatar
Its up high, way up in the corner!
Old Oct 19, 2003 | 06:54 PM
Swofford's Avatar
I just looked up in my buddies and his was a black box, so could be black as well, just look up there and find something with 5 digits on it should be it.
Old Oct 19, 2003 | 08:22 PM
Swofford, was that an Excursion you looked at????
I've looked at everything under there and don;t see a black or white box w/ a 5 digit code
Mark
Old Oct 19, 2003 | 08:40 PM
Johngs's Avatar
cajun:
I looked under my mom's '01 Expy and if you get on your back, and look up, mounted to the firewall above the parking brake, on a label stuck on a tanish electrical box, I could see a sticker with the 5 digit code listed on it.
This is on our Expedition, so it may be different on your excursion.
Here's some pics (obviously I blacked out the code itself):
https://www.f150online.com/galleries...3090&anum=4612
https://www.f150online.com/galleries...3091&anum=4612
Oh and, like the other said, its there...you just have to look. I almost didnt find it on mine.
Old Oct 19, 2003 | 10:06 PM
01 XLT Sport's Avatar
Old Oct 19, 2003 | 10:10 PM
Rockpick's Avatar
Moderator &
Old Oct 19, 2003 | 10:13 PM
Originally posted by RockPick
Well that would really screw someone up that had been drinking before coming online to F150online...
Old Oct 19, 2003 | 10:22 PM
Johngs's Avatar
Thanks.
I couldnt get the image tags to work....
[img.]http://.....[/img.] (without the dots)
didnt work...what'd I do wrong?
Old Oct 19, 2003 | 10:31 PM
Originally posted by Johngs
Thanks.
Easiest way to do it is go to the picture link you posted:
and you will see in the upper right hand corner above the picture the wording "Forum codes" select that and it gives you two options, Fullsize and Thumbnail. Just highlight and copy the code in the box and paste it in your post.
Old Oct 19, 2003 | 11:26 PM
Johngs's Avatar
cool.
thanks.
Old Oct 20, 2003 | 03:26 AM
Pics are great, thanks guys, when i get off work in the morning I will take another look see.
Mark
