Car Trouble
Old Aug 14, 2003 | 12:15 PM
Dman25's Avatar
Car Trouble
Hey guys, its not my lightning thats having the trouble, its running fine. But my dads astro wont start, its not old, its a 99, but the engine wont turn, do u think its the starter? Anyone have any suggestion on what it could be. Thanks.
Old Aug 14, 2003 | 12:21 PM
soap's Avatar
No power?? Dead battery.............
--Joe
Old Aug 14, 2003 | 12:53 PM
Dman25's Avatar
battery is fine, there is power, the engine wont turn.
Old Aug 14, 2003 | 12:59 PM
closer9's Avatar
Is it quiet, does it click, does it make any sound?
Old Aug 14, 2003 | 01:11 PM
Jag's Avatar
Jag
Check all ground connections, and make sure that the battery connections are clean.
Old Aug 14, 2003 | 02:18 PM
LE PEW's Avatar
If all the all ground connections and battery connections seem fine then try tapping on the starter itself with a hammer.
This will sometimes get will get a bad starter to turn over.
Good luck.
Old Aug 14, 2003 | 02:32 PM
Dman25's Avatar
Thanks for the suggestions guys, ill try it out later. Thanks. But there is no sound, u put the key in ignition and all the normal sounds, fuel pumps and ignition etc. happen except no engine turning. So i guess it must be the starter. Radio works and so does everything else.
Old Aug 14, 2003 | 02:41 PM
flafonman's Avatar
Wouldn't hurt to try and jump it. The starter uses waaaay more juice than the radio. You could have enough power for accessories, but not enough to make it go. Check the headlights to see if they are dim.
If you have a strong battery, then it is either starter or a ground like previous posters have pointed out.
Old Aug 14, 2003 | 04:09 PM
Rockpick's Avatar
Moderator &
It definately sounds electrical to me however; I'm no mechanic. Did it start all at once (or die all at once I should say) or was he potentially having issues earlier?
Old Aug 15, 2003 | 12:51 PM
wildchild's Avatar
turn on headlights and turn key. headlights dim out bad batt.
no sound at ALL from turning key, no click,grind,moan....could be a short in wiring. good luck finding it, easier to let shop, but expensive. took me an hour one time to find one. i was very lucky it was noticeable.
turning key returns click then nothing, could be starter or batt. acting up. tap starter as stated or try to jump as stated.
let us know what it was.
Old Aug 15, 2003 | 12:59 PM
MROLDV8's Avatar
Has it happened before? Could be a dead spot in the starter.
Also try jiggeling the shift lever in park and neutral...could be a neutral safety switch.
Old Aug 16, 2003 | 11:09 AM
Rockpick's Avatar
Moderator &
Dman... get everything worked out?
