ugh
Ok...heres my problem....my dad has a pressure washer that right now will not uh....pressurize. in other word no high pressure water comes out. its a Karcher with a Briggs & Straton 4.0hp motor. puts out about 1800psi. any ideas on what's going on here? my dad thinks that the nozzle may be clogged. i hate this stuff. it worked fine last season...
Maybe someone was abusing it in the off season
one more thing take a small bar or something small enough to to depress the ball inside the end of the hose at the coupling(plan on getting wet)...if somthings caught there it will come out then
When you are using the washer,make sure you DON'T let it idle (without spraying) for more than 60 seconds! That's the worst thing you can do to the pump. Shut the engine off and bleed off the pressure if you're not going to spray for a minute or more. They build up internal pressure and blow the seals otherwise.
RP
Originally posted by Rugby3
AJ,
What kind of sites are you surfing up there?
AJ,
It's just that I remember everything I read and when I heard "air compressor", I recalled a story about some kid exploding, because he stuck an air hose in his butt
Certainly fitting of a Darwin Award."Say no to Satan!"
