brake cable rubbing squeaking
has anyone had this problem..my right rear brake cable rubs on the frame and the leaf spring on the back right wheel well...can i reroute the brake cable under the leaf spring to stop the rubbing and squeaking?
You can reroute the cable, a possible alternative would be to split heater hose and wrap around the cable at the wear point...
I do this under the hood as well like on the p/s hoses and heater hoses...
