F-250 / Super Duty / Diesel
2004 F350 Diesel Power problem 6.0
Old Oct 20, 2022 | 06:43 PM
redheck2017's Avatar
Need some help. When I get up to highway speeds, 50+ the truck loses power and eventually won't go anymore. I can push the pedal and nothing will happen. After sitting for a couple of minutes I can turn the truck on and I can drive away. If I keep it to around 30mph or so it drives fine. Appreciate the help.
Old Oct 20, 2022 | 07:14 PM
Check the turbo for a bad turbine. Could also be a HPOP problem too.
Old Oct 20, 2022 | 10:00 PM
Could be a plugged fuel filter. You have 2 of them.
Old Oct 21, 2022 | 05:29 AM
Thank you. Turbo seems fine. Any way to test the HPOP without digging it out?
Old Oct 21, 2022 | 05:34 AM
Thank you. That would be the easiest. Any way to test that without taking them off?
Old Oct 21, 2022 | 09:09 AM
You'll need a scanner, but he goes through how to test it:
Old Oct 21, 2022 | 10:54 AM
When was the last time you changed the fuel filters?
