Left front lower. Install 1 spacer?
So my used 2014 F250 sits about 1.25 inch lower in the left front. Is it possible to install a spacer on just the left front? Any thoughts on brands? ReadyLift & Rough country have 1.5 inch blocks. Skyjacker and Zone have 1 inch blocks. Would most likely go with the 1.5 inch. Thanks.
So let me make sure I understand. Is the Ford shim kit used for an alignment; which once adjusted will address the lower height? OR Is the shim kit, like a spacer, used in conjunction with the spring before the needed alignment?
It's a block/spacer. Part number: D7TZ-5742-A
Really, all it is a rectangular piece of metal that has a hold in the middle. Ford has been using it for decades.
I really recommend you bring it to another shop like glc said, and have them take a look. You may have something else going on, but it's more than likely normal, and you just want it corrected for your likening.
I tried searching on-line for info on the D7TZ-5742-A part looks like. Was difficult find hardly anything other than it appears to me it's a shim for a leaf spring set-up. I've got coil springs.
