6.2L oil & filter suggestions?
Just picked up a used 2014 F250, Super Cab 4x4, 6.2L, with 118,000 miles. Got a while before the next oil change is needed but what synthetic oil & filter brands would you suggest? Thanks.
Any reason for the synthetic blend and not the full synthetic?
I won't be doing extended intervals; probably no more than 3500 miles. Truck will be used primarily at our farm so driving pattern won't always be consistent; time frame may be more of a factor sometimes than mileage. I'm not against using Motorcraft oil/filter; just never had an issue with not using Motorcraft in my old 1997 F150 4.6L. And since this is a newer truck and my first F250, was wondering what others were using. Especially since manufacturers always recommend their own products; even when made by another company.
I wouldn't recommend MC oil and filters if they were not top quality. You can use anything you want as long as it meets or exceeds Ford specs.
I use the MC filters and oil on most everything. Including lawn mowers.
It has to be the best oil and filters out there for the price.
I have never ever had an issue with it.
I even use the MC diesel motor oil in my Harley Sportster and run it for 3k and change it. Never an issue.
